6 Replies Latest reply on Nov 15, 2011 11:41 AM by Jason Woodcock
    Embedded font on Spark Button
    gkcohen
      I am using an embedded font for all spark labels. It works fine.
      However, the font is not applied to the button label. If I switch the font to Comic Sans MS then the font is used on the button.
      I can't figure out why this particular embedded font works in all labels, except the button label.
      Any help would be greatly appreciated.
      gkx
        • 1. Re: Embedded font on Spark Button
          gkcohen Level 1
          Does anyone have any suggestions?
          Thank you!
          gkc
          • 2. Re: Embedded font on Spark Button
            Flex harUI Adobe Employee
            Does the button have the same fontWeight and fontStyle as the Label?
            • 3. Re: Embedded font on Spark Button
              gkcohen Level 1
              Flex harUI, thank you for your response.
              I don't have either of those properties set for the label or the button.
              This is all I have:
              s|Label {
                                  fontFamily: "HelveticaNeue67_";
                                  color: #FFFFFF;
              • 4. Re: Embedded font on Spark Button
                robglobal
                You most likely need to set fontWeight and fontStyle:
                fontWeight: normal;
                fontStyle: normal;
                Some fonts will work when these properties are not set, meaning the font family only has one typeface of glyphs embedded. But if the font supports bold/italic, you need to specify these settings in the css.
                • 5. Re: Embedded font on Spark Button
                  gkcohen Level 1
                  robglobal, that was it!
                  Thank you, and Flex harUI for your help.
                  • 6. Re: Embedded font on Spark Button
                    Jason Woodcock
                    I'm seconding Robs reply here... I had a very similar issue and ended up having to set the fontWeight and fontStyle to match the embedded font. In my case it was normal and normal using a Futura family font.
                    So, my overall embed was:
                    @font-face {
                                                  src: url("assets/fonts/Futura_Book_BT.ttf");
                                                  fontFamily: "FuturaCFF";
                                                  embedAsCFF: true;
                                        @font-face {
                                                  fontFamily: "Futura";
                                                  embedAsCFF: false;
                    Then my buttons looked like
                    <s:Button fontFamily="Futura"  fontWeight="normal" label="Select"  click="hubSelectionHandler(event)" />
