12 Replies Latest reply on Nov 25, 2011 2:24 PM by Loic.Aigon
    [JS] Avoid several palettes instanciation
    Loic.Aigon Adobe Community Professional
      Hi all,
      I feel so dumb asking for such a silly question but I really can't get this one to work. I have a simple dialog (a palette). Thing is that is user clicks several times, the script outputs many windows. I want to check for a former launched palette.
      I did try everything such a global variable to edit onShow and onClose (isRunning = false), private variables.
      Any hint ?
      #targetengine 'demo'
      var myDialog = (function(){
          var w = new Window('palette');
          return{
              show:function(){
                  w.show();
      myDialog.show();
      Option 1: Global variable
      var isRunning = false;
           w.onShow = function(){ isRunning = true; }
           w.onClose = function(){ isRunning = false; }
          return{
              show:function(){
                  if(!isRunning) { w.show(); }
      myDialog.show();
      Option 2: private variable:
          return{
              show:function(){
      myDialog.show();
      I can't get it working so the palette isn't run if done already. I also tried to check for some dialog item existence like in this page but it's not helping : http://kelsocartography.com/scripts/scripts/nvkelso/registrationButtons.jsx
      TIA for any tip. I am certain it's so obvious.
      Loic
        • 1. Re: [JS] Avoid several palettes instanciation
          absqua Level 4
          Weirdly, this kind of construction will prevent two from running at once:
          function SpecialPalette(){
              w.okBtn = w.add('button', undefined, "OK");
              w.cancelBtn = w.add('button', undefined, "Cancel");
              w.defaultElement = w.okBtn;
              w.cancelElement = w.cancelBtn;
              this.show = function(){
                  if(!isRunning){
                      w.show();
                  else{
                      $.writeln("Already running.");
          var myDialog = myDialog || new SpecialPalette();
          myDialog.show();
          However, on subsequent runnings in the same session, the buttons no longer work! (So, if you have no buttons and your palette doesn't do anything, this approach will work. ) I would love some clarification of the way ScriptUI fails to work in this kind of scenario, and why.
          Jeff
          • 2. Re: [JS] Avoid several palettes instanciation
            John Hawkinson Level 5
            Why are you making it so complicated? What's wrong with your global variable and then
            if (!isRunning) { myDialog.show(); }
            • 3. Re: [JS] Avoid several palettes instanciation
              absqua Level 4
              Actually, I guess it's not so weird. You're remaking your myDialog variable at each invocation, so isRunning is false every time. Just adding a check to see if myDialog already exists will prevent it from running two at once:
              var myDialog = myDialog || (function(){
                  return{
                      show:function(){
              myDialog.show();
              But, I think you'll have the same problems I showed in my first post with things not working when you run it later in the same session.
              • 4. Re: [JS] Avoid several palettes instanciation
                That's all the point, John. I did use a global and affected it while showing and closing window. So at the time of launch, I check for isRunning.
                The problem is that it doesn't work here (I mean my place)
                • 5. Re: [JS] Avoid several palettes instanciation
                  Hi absqua,
                  Thanks for you input. I will keep your approch in mind but as you told me buttons may become inoperant, I admit this is an issue worse for me than having multiple windows
                  Thx anyway
                  Loic
                  • 6. Re: [JS] Avoid several palettes instanciation
                    Hi absqua,
                    Thanks again for the input. I was fearing something like this
                    I will try to get a way
                    Loic
                    • 7. Re: [JS] Avoid several palettes instanciation
                          return{
                              show:function(){
                      myDialog.show();
                      Hi absqua,
                      I juts retested and you got it right. I think I had issues with the running sessions. I restarted InDesign several times but probably not in the good tempo. However, now it's working.
                      Thanks to Marc too for getting me back to this lead.
                      Loic
                      • 8. Re: [JS] Avoid several palettes instanciation
                        absqua Level 4
                        I'm glad that worked for you Loic. When I'm testing scripts that run in persistent engines I usually increment the #targetengine directive after every edit ('demo', 'demo1', 'demo2', etc.) so I don't have to restart InDesign.
                        Please let us know if you experience the problems I talked about with events not being handled on subsequent runnings of the script during the same session, and if you're able to work around them. I have not been able to get that to work without rebuilding the palette on every invocation.
                        Jeff
                        • 9. Re: [JS] Avoid several palettes instanciation
                          Why didn't you write that 2hours ago ? I can't count how many restarts I did this afternoon
                          thanks a lot for that really helpful tip
                          Loic
                          • 10. Re: [JS] Avoid several palettes instanciation
                            Hi Jeff,
                            I will if I have troubles
                            • 11. Re: [JS] Avoid several palettes instanciation
                              Peter Kahrel Adobe Community Professional & MVP
                              Another method (and a simpler one, it seems to me) is to see if the palette exists:
                              if(Window.find ("palette", "demopalette") == null)
                                  var w = new Window ("palette", "demopalette");
                                  // etc.
                                  w.show();
                              Peter
                              • 12. Re: [JS] Avoid several palettes instanciation
                                Hi Peter and thx for this one. Also really valuable tip.
                                But looks like object = object || object creation is working really fine
