20 Replies Latest reply on Nov 21, 2011 10:11 AM by Flex harUI
    Datagrid and selectedItem
    jfb00 Level 3
      I have select an item using itemClick event of an advanced data grid like:
      my_adg.selectedItem = my_adg.dataProvider[event.rowIndex];
      If I check later my_adg.selectedIndex I see the index value but if i check a property like:
      my_adg.selectedItem.CUSTOMER_ID;
      The result of the debugger of my_adg.selectedItem is null.
      Any ideas why? It should have the item object.
      Thanks!
        • 1. Re: Datagrid and selectedItem
          jfb00 Level 3
          I have two datagrids and I want to sync the scroll in both datagrids and also the item selected.
          Here are my funcitons:
          private function select_adg_row(event:ListEvent):void{
                          var rowIndex:Number = event.rowIndex;
                          first_dg.selectedIndex = rowIndex;
                          first_dg.validateNow();
                          second_dg.selectedItem = second_dg.dataProvider[rowIndex];
                          second_dg.validateNow();
                      private function dg_scrollHandler(event:ScrollEvent):void
                          if (event.currentTarget.name == "first_dg"){
                              second_dg.verticalScrollPosition = first_dg.verticalScrollPosition;
                              second_dg.horizontalScrollPosition = first_dg.horizontalScrollPosition;
                          if (event.currentTarget.name == "second_dg"){
                              first_dg.verticalScrollPosition = second_dg.verticalScrollPosition;
                              first_dg.horizontalScrollPosition = second_dg.horizontalScrollPosition;
          Like I said before, the item is not selected and now the scrolls disappear.
          Any body had the same experience before?
          • 2. Re: Datagrid and selectedItem
            Flex harUI Adobe Employee
            Might be rowIndex + verticalScrollPosition.
            • 3. Re: Datagrid and selectedItem
              jfb00 Level 3
              What do you mean Alex?
              I dont understand.
              • 4. Re: Datagrid and selectedItem
                I don’t think rowIndex is the position in the datagrid, I think it is the row on the screen.  Actually, I think there is a reference to the itemRenderer in the event, and its data property should be what you want.
                • 5. Re: Datagrid and selectedItem
                  jfb00 Level 3
                  I use this:
                  my_adg.selectedItem = event.itemRenderer.data;
                  The same issue, still null.
                  Any other property? Maybe I need to do this in different way?
                  Why the scrollbars doesn't show in the target datagrid after I use the scroll in the source or first datagrid?
                  • 6. Re: Datagrid and selectedItem
                    Zolotoj Level 3
                    Did you try my_adg.selectedItem.@CUSTOMER_ID;
                    • 7. Re: Datagrid and selectedItem
                      jfb00 Level 3
                      I try different ways and still not working. I don't know why selectedItem doesn't accept any values.
                      Best
                      • 8. Re: Datagrid and selectedItem
                        Is the object you are assigning actually in the dataProvider?  Or is it a clone or copy?
                        • 9. Re: Datagrid and selectedItem
                          jfb00 Level 3
                          Yes, It is in the dataprovider. This is itemClick event from the datagrid.
                          In event.itemRenderer.data I can see the data.
                          • 10. Re: Datagrid and selectedItem
                            Is it in the destination dataProvider?
                            Post a simple test case.
                            • 11. Re: Datagrid and selectedItem
                              jfb00 Level 3
                              Alex,
                              Doing my test case i found that the issue is doing a sort on the datagrid. If I don't perform the sort it works fine.
                              Why is the sort affecting the array?
                              Here is my sort funciton:
                              second_dg.dataProvider = acSample;
                              sortADG(second_dg, "Fname");
                              private function sortADG(adg:AdvancedDataGrid, field:String):void{
                                              var sort:Sort = new Sort();
                                              sort.fields = [new SortField(field)];
                                              sort.fields[0].numeric = false;
                                              adg.dataProvider.sort = sort;
                                              adg.dataProvider.refresh();
                              • 12. Re: Datagrid and selectedItem
                                Don’t know for sure.  I’d have to see a test case.  I do know that a sort changes the way we try to find an object in the dataProvider, and setting selectedItem is therefore going to go down a different code path.
                                • 13. Re: Datagrid and selectedItem
                                  jfb00 Level 3
                                  Also, when i jump from one tab to the other, the scroll bar disappear ot it is cut off. Any ideas?
                                  Thanks!
                                  Here is my test sample:
                                  <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                                                  layout="vertical"
                                                  verticalAlign="middle"
                                                  backgroundColor="white"
                                                  initialize="getData()">
                                      <mx:Script>
                                          <![CDATA[
                                              import mx.collections.ArrayCollection;
                                              import mx.collections.Sort;
                                              import mx.collections.SortField;
                                              import mx.controls.AdvancedDataGrid;
                                              import mx.controls.Alert;
                                              import mx.events.ListEvent;
                                              import mx.events.ScrollEvent;
                                              import mx.rpc.events.FaultEvent;
                                              import mx.rpc.events.ResultEvent;
                                              [Bindable] private var acSample:ArrayCollection = new ArrayCollection([
                                                  {Fname: "Kranthi", Lname:"Kata", dob:"21/10/1972", Amount_1:10000, Amount_2:0, Amount_3:0, Rate_1:23, Rate_2:43, Rate_3:0},
                                                  {Fname: "Vasanth", Lname:"Lola", dob:"12/01/1980", Amount_1:5000,  Amount_2:0, Amount_3:0, Rate_1:23, Rate_2:43, Rate_3:0},
                                                  {Fname: "Sample1", Lname:"Lola", dob:"12/01/1982", Amount_1:10000, Amount_2:0, Amount_3:0, Rate_1:23, Rate_2:43, Rate_3:0},
                                                  {Fname: "Basanth", Lname:"Viola",dob:"5/01/1980",  Amount_1:5000,  Amount_2:0, Amount_3:0, Rate_1:23, Rate_2:43, Rate_3:0},
                                                  {Fname: "Basanth", Lname:"Chuck",dob:"5/01/1980",  Amount_1:5000,  Amount_2:0, Amount_3:0, Rate_1:23, Rate_2:43, Rate_3:0},
                                                  {Fname: "Sample2", Lname:"Viola",dob:"2/06/1985",  Amount_1:10000, Amount_2:0, Amount_3:0, Rate_1:23, Rate_2:43, Rate_3:0},
                                                  {Fname: "Manoj",   Lname:"Pat",  dob:"16/09/1978", Amount_1:5000,  Amount_2:0, Amount_3:0, Rate_1:23, Rate_2:43, Rate_3:0},
                                                  {Fname: "John M",  Lname:"Mela", dob:"15/01/1974", Amount_1:10000, Amount_2:0, Amount_3:0, Rate_1:23, Rate_2:43, Rate_3:0},
                                              private function getData():void{
                                                  first_dg.dataProvider = acSample;
                                                  sortADG(first_dg, "Fname");
                                                  second_dg.selectedIndex = rowIndex;
                                                  //second_dg.selectedItem = event.itemRenderer.data; //second_dg.dataProvider[rowIndex];
                                              private function editForm(AC:ArrayCollection, DG:AdvancedDataGrid):void{
                                                  if (AC.length == 0){
                                                      Alert.show("No rows to be edited")}
                                                  else if (DG.selectedItem == null){
                                                      Alert.show("Not row was selected")
                                                  }else{
                                                      Alert.show("Select Item: " + DG.selectedItem.Fname)
                                      </mx:Script>
                                      <mx:TitleWindow x="0" width="100%" height="40%" layout="absolute" title="Sample ADG" horizontalCenter="0" verticalCenter="0" >
                                          <mx:TabNavigator id="my_tn" x="0" y="0" width="100%" height="100%" creationPolicy="all">
                                              <mx:Canvas label="FIRST" width="100%" height="100%" horizontalScrollPolicy="off" verticalScrollPolicy="off" creationPolicy="all">
                                                  <mx:HBox>
                                                      <mx:Button label="Edit" click="editForm(acSample, second_dg)" />
                                                  </mx:HBox>
                                                  <mx:AdvancedDataGrid scroll="dg_scrollHandler(event)" id="first_dg" width="100%" top="30" bottom="10" left="10" right="10" itemClick="select_adg_row(event)"
        editable="false" headerWordWrap="true" textAlign="left" horizontalScrollPolicy="auto"
        sortableColumns="false" resizableColumns="true">
                                                      <mx:columns>
                                                          <mx:AdvancedDataGridColumn headerText="First Name" dataField="Fname" textAlign="left"  width="150" />
                                                          <mx:AdvancedDataGridColumn headerText="Last Name" dataField="Lname" textAlign="left"  width="150"  />
                                                          <mx:AdvancedDataGridColumn headerText="BDay" dataField="dob" textAlign="left"  width="100" />
                                                      </mx:columns>
                                                  </mx:AdvancedDataGrid>
                                              </mx:Canvas>
                                              <mx:Canvas label="SECOND" width="100%" height="100%" horizontalScrollPolicy="off" verticalScrollPolicy="off" creationPolicy="all">
                                                  <mx:AdvancedDataGrid scroll="dg_scrollHandler(event)" id="second_dg" width="100%" top="30" bottom="10" left="10" right="10" itemClick="select_adg_row(event)"
                                                      <mx:columns>
                                                          <mx:AdvancedDataGridColumn headerText="ID" dataField="ID" width="0" visible="false"  />
                                                      </mx:columns>
                                              </mx:Canvas>
                                          </mx:TabNavigator>
                                      </mx:TitleWindow>
                                  </mx:Application>
                                  • 14. Re: Datagrid and selectedItem
                                    I’m not seeing any problem with your test case.  What are the steps to reproduce?
                                    • 15. Re: Datagrid and selectedItem
                                      jfb00 Level 3
                                      Hi Alex,
                                      Sorry, I forgot to explain.
                                      Please try to replace this code:
                                      FOR
                                      //second_dg.selectedIndex = rowIndex;
                                      At the time of click Edit, it will show message that it was not record selected because selectedIem is null.
                                      If you comment the sort line "sortADG(first_dg, "Fname");" , it works.
                                      • 16. Re: Datagrid and selectedItem
                                        I am not able to reproduce the problem.
                                        • 17. Re: Datagrid and selectedItem
                                          jfb00 Level 3
                                          Really, I am using Flash builder 3 and Flez SDK 3.5.
                                          What are you using?
                                          Thanks Alex
                                          • 18. Re: Datagrid and selectedItem
                                            I generally assume folks are running the latest version.
                                            It looks like there was a bug in 3.x that is fixed in 4.
                                            • 19. Re: Datagrid and selectedItem
                                              jfb00 Level 3
                                              gggg... I need to move to 4.
                                              Can I use SDK 4.5 or the latest under FBuilder 4?
                                              Thanks!
                                              • 20. Re: Datagrid and selectedItem
                                                I don’t think that is officially supported.
