0 Replies Latest reply on Nov 16, 2011 8:01 AM by Mahesh_JW
    InDesign Table Fit (Clear overflow, Height and Row fit)
    Mahesh_JW Level 1
      Hi All,
      I am using MagicFit.jsx for fit the table. But it does not clear the overflow and it does not fit the Height. I want to do all of this.
      Plz suggest.
      MagicFit.jsx
      function MagicFit(){
          app.scriptPreferences.version = 4.0;          //Because I am using CS5
          MagicFit_1()
          app.scriptPreferences.version = 6.0;
      function MagicFit_1(){
              MagicFit 2.1b for InDesign CS / CS2 -- 01/18/06
              Fits to content the WIDTH of the selected text container(s)
              Features:
              - Fits selected TextFrame(s) width to content
              - 1st call: "strict" fitting (preserve each lines length)
              - 2nd call (within 2 secs) : "fluid" fitting (preserve height)
              - (NEW) Alternate fitting of table column(s) if selected
              - (NEW) Compute a minimal width by parsing embedded objects
              - (NEW) Runs on selected frames, CELLS, groups, insertion pt
              Installation & usage:
              0) !! CS2 users only !!
                 Rename this script file with .jsx extension
                 (activating extend script features)
              1) Put the present file into the Presets/Scripts/ subdir
              2) Run InDesign, open a document and select object(s) to fit
                 (or put insertion point into)
              3) Run the script via Window > Automation > Scripts
                 and double-clic on MagicFit.js
                 Alternate way: assign a keyboard shortcut to the script via
                 Edit > Keyboard Shortcuts... > Product area:"Scripts"
              Help (FR) : http://marcautret.free.fr/geek/indd/magicfit/
                  (sorry, thats a french web page!)
                      Feedbacks : marcautret@free.fr
          //            SETTINGS
          var LATENCE = 2;         // in seconds (default:2)
          var PRECISION = 0.5;    // in pts (default:0.5)
          var APP_INT_VERSION = parseInt(app.version);
          //            TOOLBOX FUNCTIONS
          /*void*/ function exitMessage(/*exception*/ ex){
              alert("Error:\n" + ex.toString());
              exit();
          //            DOCUMENT METHODS
          /*void*/ Document.prototype.setUnitsTo = function(/*units*/ newUnits){        // units can be single value (horiz=vert) or array(horizUnits, vertUnits)
              var arrUnits = (newUnits.length) ? newUnits : new Array(newUnits,newUnits);
              this.viewPreferences.horizontalMeasurementUnits = arrUnits[0];
              this.viewPreferences.verticalMeasurementUnits = arrUnits[1];
          /*arr2*/ Document.prototype.getUnits = function(){
              return(Array(
                  this.viewPreferences.horizontalMeasurementUnits,
                  this.viewPreferences.verticalMeasurementUnits));
          /*bool*/ Document.prototype.withinDelay = function(){
              if (this.label)
                  return( (Date.parse(Date())-this.label) <= LATENCE*1000 );
              return(false);
          /*void*/ Document.prototype.storeTimeStamp = function(){
              this.label = Date.parse(Date()).toString();
          //            GENERIC METHODS (OBJECT LEVEL)
          // Returns the "fittable-container" corresponding to THIS
          // Return array or collection HorizFit-compliant
          // NULL if failure
          /*arr*/ Object.prototype.asObjsToFit = function(){
              switch(this.constructor.name){
                  case "TextFrame" :            // textframe -> singleton this
                      return(Array(this));
                  case "Cell" :                // cells -> parent columns
                      var r = new Array();
                      // !! [CS1] Cell::parentColumn === Cell !!
                      // !! [CS2] Cell::parentColumn === Column !!
                      // !! [CS2] Cells::lastItem().parentColumn BUG !!
                      var c0 = this.cells.firstItem().name.split(":")[0];
                      var c1 = this.cells.lastItem().name.split(":")[0];
                      for (var i=c0 ; i<=c1; i++)
                          r.push(this.parent.columns[i]);
                      return(r);
                  case "Table" /*CS2*/ :        // table -> columns
                      return(this.columns);
                  case "Group" :                // group -> textFrames
                      return((this.textFrames.length>0) ? this.textFrames : null);
                  case "Text" :                // selection is Text or InsertionPoint
                  case "InsertionPoint" :        // -> run on container
                      var textContainer = this.getTextContainer();
                      return((textContainer) ? textContainer.asObjsToFit() : null);
                  default:
                      return(null);
          // Returns Text's or InsertionPoint's container :
          // Type returned: TextFrame or Cell - NULL if failure
          /*obj*/ Object.prototype.getTextContainer = function(){
              try{ // try...catch because of CS2 behaviour
                  if (this.parent.constructor.name == "Cell")
                      return(this.parent);
                  if (this.parentTextFrames)        // plural in CS2
                      return(this.parentTextFrames[0]);
                  if (this.parentTextFrame)    // single in CS1
                      return(this.parentTextFrame);
                  return(null);
              }catch(ex) {return(null);}
          // Parse embedded "objects": tables, pageitems [including graphics]
          // and returns the max width
          // !! All parsed objects have to provide a computeWidth method !!
          /*int*/ Object.prototype.computeIncludedObjectsWidth = function(){
              var objsNames = new Array("pageItems","tables"); // could be extended
              var objsWidth = 0;
              var w = 0;
              for (var j=objsNames.length-1 ; j>=0 ; j--){
                  for (var i=this[objsNames[j]].length-1 ; i>=0 ; i--){
                      try{
                          w = this[objsNames[j]][i].computeWidth({VISIBLE:true});
                      }catch(ex){
                          w=0;
                      if (w > objsWidth) objsWidth=w;
              return(objsWidth);
          // Generic computeWidth method for bounded objects
          // VISIBLE true -> external width
          // VISIBLE false -> internal width
          /*int*/ Object.prototype.computeWidth = function(/*bool*/ VISIBLE){
              if (VISIBLE){
                  if (this.visibleBounds)
                      return(this.visibleBounds[3]-this.visibleBounds[1]);
              else{
                  if (this.geometricBounds)
                      return(this.geometricBounds[3]-this.geometricBounds[1]);
              return(0);
          // Override Object::computeWidth for Table : returns simply the width
          /*int*/ Table.prototype.computeWidth = function(){
              return(this.width);
          // Returns chars count for each LINE of this (-> array)
          // empty array  IF  this.lines==NULL  OR  this.lines.length==0
          /*arr*/ Object.prototype.createLinesSizesArray = function(){
              r = new Array();
              if (this.lines)
                  for (var i=this.lines.length-1; i>=0 ; i--)
                      r.unshift(this.lines[i].characters.length);
              return(r);
          // Compare chars count beetween THIS and arrSizes argument
          // (generic method just presuming that THIS have lines prop.)
          // -> TRUE if isoceles, FALSE if not
          /*bool*/ Object.prototype.isoceleLines = function(/*arr*/ arrSizes){
              if (this.lines.length != arrSizes.length) return(false);
              for (var i=arrSizes.length-1 ; i>=0 ; i--)
                  if (arrSizes[i] != this.lines[i].characters.length)
                      return(false);
              return(true);
          //            TEXTFRAME METHODS
          // intanciate the part of the abstract process for TextFrames
          /*bool*/ TextFrame.prototype.isEmpty = function(){
              return(this.characters.length==0);
          /*bool*/ TextFrame.prototype.isOverflowed = function(){
              return(this.overflows);
          /*int*/ TextFrame.prototype.getWidth = function(){
              return(this.computeWidth({VISIBLE:false}));
          // Redim the frame in width by widthOffset
          /*void*/ TextFrame.prototype.resizeWidthBy = function(/*int*/ widthOffset){
              this.geometricBounds = Array(
                  this.geometricBounds[0],
                  this.geometricBounds[1],
                  this.geometricBounds[2],
                  this.geometricBounds[3] + widthOffset);
          // Returns the minWidth of the frame according to embedded content
          // and inner space
          // inner width space
          /*int*/ TextFrame.prototype.computeMinWidth = function(){
              var inSpace = this.textFramePreferences.insetSpacing;
              var inWidth = (inSpace.length) ?
                  inSpace[1] + inSpace[3] :    // distinct left & right inspace
                  2*inSpace;                    // global inspace
              return(this.computeIncludedObjectsWidth() + inWidth);
          /*int*/ TextFrame.prototype.getCharsCount = function(){
              return(this.characters.length);
          /*int*/ TextFrame.prototype.getLinesCount = function(){
              return(this.lines.length);
          // Return chars count BY LINE (-> array)
          /*arr*/ TextFrame.prototype.getLinesSizes = function(){
              return(this.createLinesSizesArray());
          // YES -> -1  , NOT -> 1
          /*int*/ TextFrame.prototype.preserveCharsCount = function(/*int*/ charsCount){
              return( (this.characters.length != charsCount) ? 1 : -1 );
          // Indicates whether:
          // - chars count equals linesCount
          // - frame DOES NOT overflow
          /*int*/ TextFrame.prototype.preserveLinesCount = function(/*int*/ linesCount){
              return( ((this.overflows) || (this.lines.length != linesCount)) ? 1 : -1 );
          // each x line isoceles linesSizes[x]
          /*int*/ TextFrame.prototype.preserveLinesSizes = function(/*arr*/ linesSizes){
              return( (this.isoceleLines(linesSizes)) ? -1 : 1 );
          //            COLUMN METHODS
          // intanciate the part of the abstract process for Columns
          /*bool*/ Column.prototype.isEmpty = function(){
              for (var i=this.cells.length-1; i>=0 ; i--)
                  if (this.cells[i].characters.length>0) return(false);
              return(true);
          // Indicates whether AT LEAST a cell overflows
          // !! We can't trust Column::overflows !!
          /*bool*/ Column.prototype.isOverflowed = function(){
              for (var i=this.cells.length-1 ; i>= 0 ; i--)
                  if (this.cells[i].overflows) return(true);
              return(false);
          /*int*/    Column.prototype.getWidth = function(){
              return(this.width);
          // Redim the column width by widthOffset
          // !! we HAVE TO update the display after resizing !!
          /*void*/ Column.prototype.resizeWidthBy = function(/*int*/ widthOffset){
              this.width += widthOffset;
              // updates the display
              if (APP_INT_VERSION > 3)        // CS2+
                  this.recompose();
              else{
                  // CS -- thx to Tilo for this hack --
                  for(var i = this.cells.length - 1 ; i >= 0 ; i-- ){
                      // Comparing the cell contents against null
                      // seems to internally recompose the cell!
                      if (this.cells[i].contents == null) {}
          // Returns the minWidth of the column according to embedded content
          // and inner space
          /*int*/ Column.prototype.computeMinWidth = function(){
              var iCell = null;
              var w = 0;
              var r = 0;
              for (var i=this.cells.length-1 ; i>= 0 ; i--){
                  iCell = this.cells[i];
                  w = iCell.computeIncludedObjectsWidth() +
                      iCell.leftInset + iCell.rightInset;
                  if (w > r) r = w;
              return(r);
          // Returns SIGNED chars count BY CELL (negatif if overflows)
          /*arr*/ Column.prototype.getCharsCount = function(){
              var sgn = 0;
                  sgn = (this.cells[i].overflows) ? -1 : 1;
                  r.unshift(sgn * this.cells[i].characters.length);
              return(r);
          // Returns lines count BY CELL
          /*arr*/ Column.prototype.getLinesCount = function(){
                  r.unshift(this.cells[i].lines.length);
              return(r);
          // Matrix: returns the chars count BY LINE / BY CELL
          /*bi-arr*/ Column.prototype.getLinesSizes = function(){
                      r.unshift(this.cells[i].createLinesSizesArray());
              return(r);
          // overflow sign BY CELL x equals sgn(charsCount[x])
          // YES -> -1  , NO -> 1
          /*int*/ Column.prototype.preserveCharsCount = function(/*arr*/ charsCount){
              var sgn = 0;
                  if (sgn * charsCount[i] < 0) return(1);
              return(-1);
          // - lines count BY CELL x equals linesCount[x]
          // - no cell overflows
          /*int*/ Column.prototype.preserveLinesCount = function(/*arr*/ linesCount){
                  if (this.cells[i].overflows) return(1);
                  if (this.cells[i].lines.length != linesCount[i]) return(1);
              return(-1);
          // - in each CELL x, each LIGNE y isoceles linesSizes[x][y]
          // (if a cell overflows, returns 1)
          /*int*/ Column.prototype.preserveLinesSizes = function(/*bi-arr*/ linesSizes){
                  if (this.cells[i].isoceleLines(linesSizes[i]) == false) return(1);
              return(-1);
          //            METHODES CENTRALES
          // !! [CS2 only] Prevents a strange crash on wide table columns selection !!
          // !! Thx to Tilo for this hack --
          /*void*/ Object.prototype.manageFit = function(/*bool*/ FLUIDFITTING){
              if (APP_INT_VERSION>=4){
                  $.gc();
              // NOP if empty object
              if (this.isEmpty()) return;
              // min width to preserve
              var minWidth = this.computeMinWidth();
              // let's go!
              this.processFit(FLUIDFITTING, minWidth);
          // Fits this object
          // if FLUIDFITTING -> fluid fitting, else: strict fitting
          // minWidth sets the threshold
          /*void*/ Object.prototype.processFit = function(/*bool*/ FLUIDFITTING, /*int*/ minWidth){
              if (FLUIDFITTING){ // FLUID FITTING
                  if (this.isOverflowed()){ // NB : overflowed CELLS are "transparent"
                      var charsCount = this.getCharsCount();
                      var evalFlag = function(thisObj){return(thisObj.preserveCharsCount(charsCount));}
                  else{
                      var linesCount = this.getLinesCount();
                      evalFlag = function(thisObj){return(thisObj.preserveLinesCount(linesCount));}
              else{ // STRICT FITTING
                    // NB : overflowed columns are "intouchable"
                  if ((this.constructor.name=="Column") && (this.isOverflowed()))
                      return;
                  var linesSizes = this.getLinesSizes();
                  var evalFlag = function(thisObj){return(thisObj.preserveLinesSizes(linesSizes));}
              // DICHOTOMIC LOOP
              var sgnFLAG = -1;
              var w = ( this.getWidth() - minWidth ) / 2;
              while (w >= PRECISION){
                  // resize width by +/- w
                  this.resizeWidthBy(sgnFLAG*w);
                  // +1 = increase | -1 = reduce
                  sgnFLAG = evalFlag(this);
                  // divide
                  w = w/2;
              // exit with sgnFLAG==+1 -> undo last reduction -> +2w
              if (sgnFLAG>0) this.resizeWidthBy(2*w);
          // MAIN PROGRAM
          if ( app.documents.length > 0 ){
              if ( app.activeWindow.selection.length > 0 ){
                  try{
                      var thisDoc = app.activeDocument;
                      var FLUIDFLAG = thisDoc.withinDelay();
                      var memUnits = thisDoc.getUnits();
                      thisDoc.setUnitsTo(MeasurementUnits.points);
                      var selObjs = app.activeWindow.selection;
                      var objsToFit = null;
                      for (var i=selObjs.length-1 ; i>=0 ; i--){
                          objsToFit = selObjs[i].asObjsToFit();
                          if (objsToFit){
                              for (var j=objsToFit.length-1 ; j>=0 ; j--)
                                  objsToFit[j].manageFit(FLUIDFLAG);
                      thisDoc.setUnitsTo(memUnits);
                      thisDoc.storeTimeStamp();
                  }catch(ex){
                      exitMessage(ex);
              else
                  alert("No object selected!");
          else
              alert("No document opened!");
