6 Replies Latest reply on Nov 17, 2011 11:25 PM by MarcelSteffen
    Stream Error 2032 - No mx_4.5.1.xxxxx.swf in bin-debug
    MarcelSteffen
      Hello everybody,
      I have a strange behaviour when running the example from this site:
      http://blogs.adobe.com/aharui/2011/02/sparkdatagridwithhierarchy.html
      I get a stream error for the file mx_4.5.0.20967.swf which is not in the bin-debug folder when I build my application.
      I minimized the example to identify which line of code is responsible. The smallest application I could come up with is this.
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
          <fx:Declarations>
              <mx:HierarchicalData/>
          </fx:Declarations>
      </s:Application>
      As soon as I declare any mx class which implements IVisualElement, like a mx:DataGrid the missing RSL-file appears in the bin-debug folder.
      When I go to the properties and uncheck the 'Use local debug runtime shared libraries when debugging' option in the build path settings, clean the project an build again, then alle RSL-files change to .swz an even with the above example I get an mx_4.5.0.20967.swz. So no more stream error
      Regarding all this I have 3 questions.
      1. Why is their this distinction wether I use GUI classe from the mx package or not?
      2. Why do the debug RSLs not include the mx-file by default?
      3. Why do I have the feeling that not many users encoutered this problem. Before I checked the build path settings everything was on factory settings in FlashBuilder. So IMO more users should have this problem.
      Thanks in advance!
      Best regards,
      Marcel
