2 Replies Latest reply on Nov 17, 2011 11:01 AM by Adam-C
    Put _movie.frame in D11.5?
    Professor S. Level 1
      The documentation says _movie.frame returns the number of the current frame of the movie. I want a single print button to print the current frame, which could be 1 through 10.  So I need to be able to ask my projector in Lingo what frame I'm on.   _movie.frame returns an error for me. How do I read the current frame number please?
        • 1. Re: Put _movie.frame in D11.5?
          Why do I figure out my own answers after two hours of research and then it comes to me two seconds after I post it.  Well, partly because of similar posts that I could not find.  Oh well, it's
          put the frame
          or if the frame = 5 then
          print it sort of
          • 2. Re: Put _movie.frame in D11.5?
            Adam-C Level 2
            If you're using Director MX2004 or 11 then _movie.frame should work fine - it always does for me anyway. the frame is the verbose syntax equivalent.
            Do you generally use Lingo's dot-syntax or its verbose syntax? If the latter then I'm wondering whether the problem is occurring because the dot-syntax _movie.frame is causing an ambiguity within your verbose-syntax code.
            Also, the problem may be that you're using the put command - this outputs a value to the message window, but doesn't make that value available to the rest of your handler or script.
            The following should work just fine from a behaviour, then:
            on printFrame me
                 printFrom(_movie.frame, _movie.frame)
            end
            (look-up printFrom() in the scripting dictionary to find out more about it)
