3 Replies Latest reply on Nov 18, 2011 6:10 AM by Rohit . Kumar
    Can't deploy a model that includes a service
    ecchuckles Level 1
      I'm using flashbuilder 4.5.1 & lcds 3.1 and I'm trying to deploy a model that includes a service something like this:
      <service name="Zoo">
              <annotation name="ActionScriptGeneration">
                  <item name="ServiceType">RemoteObject</item>
              </annotation>
              <function name="scoop" return-type="void">
               <parameter name="animal" type="opaque"/>
              </function>
          </service>
      When I try to deploy it I get this lcds error about expecting an annotation.  I've successfully used this capability in the past, any suggestions or workarounds?
      thanks in advance
        • 1. Re: Can't deploy a model that includes a service
          Rohit . Kumar Adobe Employee
          The FlashBuilder error dialog states that the function element only allows annotation as a child element. Your declaration for service's function arguments is incorrect. Flash Builder should have flagged this as an error in the Errors tab. In any case, the declaration should be (note bold line):
                  </annotation>
                  <function name="scoop" arguments="animal:opaque" return-type="void"/>
          </service>
          For complete syntax, refer to the LCDS 3.1 modelling guide.
          Hope that helps you move forward.
          Rohit
          • 2. Re: Can't deploy a model that includes a service
            Oscar Nazario
            Rohit,
            Thank you very much for the explanation.
            By the way, the Flash Builder 4.5  Data Model perspective displays the following when you hover over a <function…> tag and appears to be in error. See text in red below.
            Defines the prototype of an externally defined function within a service.
            For information about functions, including how to add them in Design mode, see Add service functions. Can
            appear
            A function element can only appear as an immediate child of a service element. Attributes
            Attribute
            Req/Opt
            Default
            Description
            name
            Required
            Specifies the function name.
            arguments (deprecated)
            Optional
            Note: The arguments attribute is deprecated in LiveCycle Data Services 4.5. For prolonged support an d
            augmented functionality, use the parameters attribute.
            Specifies the names and types of the function’s arguments. If present, the value specified for arguments
            takes the form name:type, where name and type denote argument names and types, respectively.
            Names must be valid data model language names, and types must be valid data model language type
            expressions
            Instead of an arguments attribute, you can use child parameter elements. If you use parameter elements,
            you cannot include the arguments attribute.
            parameters
            Optional
            Specifies the names and types of the function arguments. A missing parameters attribute indicates that the
            function takes zero arguments.
            If present, the value specified for arguments takes the form name:type[=default], where name , type, and
            default denote parameter names and types, and default values respectively. The name and type are required.
            The default value is optional.
            Separate mutliple parameters with commas.
            Default values can be literal values or expressions.
            expressions.
            Instead of a parameters attribute, you can use child parameter elements. If you use parameter elements, you
            cannot include the parameter attribute.
            return-type
            Optional
            Specifies the return type of the function.
            You must specify the type of data that is returned. However, the attribute is optional because you can use a
            child return-type element instead. Child elements
            A function element can contain zero or more annotation and parameter elements, and zero or one return-
            type elements. Example
            The data model in the following example contains a service with two functions, both of which are called
            from expressions in properties of an entity. <model xmlns="http://ns.adobe.com/Fiber/1.0">
                <entity name="Applicant" persistent="true">
                    <property name="name" type="string"/>
                    <property name="ssn" type="string"/>
                    <property name="age" type="integer"/>
                    <property name="state" type="string"/>
                    <property name="score" expr="CreditScore.getCreditScore(ssn)"/>
                    <property name="risk" expr="CreditScore.getRisk(state, age, score)"/>
                    <id name="id" type="integer"/>
                </entity>
                <service name="CreditScore">
                    <function name="getCreditScore" parameters="ssn:string" return-type="integer"/>
                    <function name="getRisk" parameters="state:string, age:integer,
                         score:integer" return-type="integer"/>
                </service>
            </model> <
            Maybe you can pass this info along so it gets fixed on the next Data Model plugin release…
            Oscar
            • 3. Re: Can't deploy a model that includes a service
              I should have added that, the support for parameter element within function element was not part of LCDS 3.1 schema and was introduced later on. The error message you see corresponds to the LCDS 4.5 schema.
              BTW, your post does not mention if you are using Modeller 3.1 plugin or not. There is a known issue of using Modeller 3.11 plugin in FB 4.5 with LCDS 3.1, which causes something similar to happen (see the following post for location etc.) In either case, it will help clarify things.
              Rohit
