5 Replies Latest reply on Nov 19, 2011 1:38 PM by kevinklin
    I only want state to change when set data is called in GridItemRenderer
    nikos101 Level 2
      I have a here  GridItemRenderer, however when the user mouse overs it the states reverts to critical, I only want state to change when set data is called
      <s:GridItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                          xmlns:mx="library://ns.adobe.com/flex/mx"
                          clipAndEnableScrolling="true" currentState="critical">
          <fx:Script>
              <![CDATA[
                  import utils.UsefulConstants;
                  override public function set data(value:Object):void
                      super.data = value;
                      //set the red text to show the old value
                      if(data){
                          if(!data.dateAcknowledged){
                              this.currentState = 'critical';
                          else if(data.dateReceived.time - data.dateReceived.time > UsefulConstants.oneDay){
                              this.currentState = 'warning';
                          else if(data.dateReceived.time - data.dateReceived.time < UsefulConstants.oneDay){
                              this.currentState = 'safe';
                          else if(data.status == 'CLOSED'){
                          else{
                              throw new Error('Unforseen condtions for data.dateReceived.time - data.dateReceived.time');
          </fx:Script>
          <s:states>
              <s:State name="critical"/>
              <s:State name="warning"/>
              <s:State name="safe"/>
          </s:states>
          <s:HGroup x="-1" y="-1" width="100%" horizontalAlign="center" verticalAlign="middle" height="100%" >
              <s:Graphic id="icon" includeIn="critical,warning" x="-1" y="5" width="16" height="20"
                         version="2.0" viewHeight="600" viewWidth="200">
                  <s:Ellipse width="88" height="401" x="58" y="37">
                      <s:fill>
                          <s:SolidColor alpha="1" color="#FE4744"
                                        color.warning="#Ff7f45"/>
                      </s:fill>
                      <s:stroke>
                          <s:SolidColorStroke color="#FE3D44" alpha="1" weight="1"/>
                      </s:stroke>
                  </s:Ellipse>
                  <s:Ellipse width="51" height="97" x="79" y="478">
                      <s:fill>
                          <s:SolidColor alpha="1" color="#FD8E9E"
                                        color.warning="#f69240"/>
                      </s:fill>
                      <s:stroke>
                          <s:SolidColorStroke color="#942EC8" alpha="0.62"/>
                      </s:stroke>
                  </s:Ellipse>
                  <s:Ellipse width="31" height="147" x="72" y="122">
                      <s:fill>
                      </s:fill>
                      <s:stroke>
                      </s:stroke>
                  </s:Ellipse>
              </s:Graphic>
              <s:Graphic
                         includeIn="safe" width="20" height="20" version="2.0"
                         viewHeight="600" viewWidth="600">
                  <s:Path data="M49,294 L245,410L551,116C551,116 259,519 257,516L49,294Z " winding="nonZero" x="-13.5" y="-57.3" scaleX="1.051689863204956" scaleY="1.122194528579712">
                      <s:fill>
                          <s:LinearGradient x="49" y="115.95" scaleX="402.4029386075604" rotation="18.660078428615776">
                              <s:GradientEntry color="#359F66" ratio="0.006535947712418301"/>
                              <s:GradientEntry color="#7EFA4A" ratio="0.9803921568627451"/>
                          </s:LinearGradient>
                      </s:fill>
                      <s:stroke>
                          <s:SolidColorStroke color="#C6A470" alpha="1" weight="1"/>
                      </s:stroke>
                  </s:Path>
              </s:Graphic>
          </s:HGroup>
      </s:GridItemRenderer>
        • 1. Re: I only want state to change when set data is called in GridItemRenderer
          kevinklin Adobe Employee
          Override getCurrentRendererState() to return the correct state depending on the data.
          • 2. Re: I only want state to change when set data is called in GridItemRenderer
            nikos101 Level 2
            cheers mate, its sometime hard keeping upto date with how things changed in spark
            • 3. Re: I only want state to change when set data is called in GridItemRenderer
              nikos101 Level 2
              I have only 2 items in my dp, however this only gets called once when the db is assigned:
              override protected function getCurrentRendererState():String
              super.getCurrentRendererState();
              if(data){
              return 'critical';
              else if(data.dateAcknowledged.time - data.dateReceived.time >= UsefulConstants.oneDay){
              return 'warning';
              else if(data.dateAcknowledged.time - data.dateReceived.time < UsefulConstants.oneDay){
              return 'safe';
              return 'safe';
              else{
              trace(data.dateAcknowledged.time + ' ' + data.dateReceived.time + ' ' + UsefulConstants.oneDay);
              trace(data.dateAcknowledged.time - data.dateReceived.time + ' ' + UsefulConstants.oneDay);
              return null;
              • 4. Re: I only want state to change when set data is called in GridItemRenderer
                nikos101 Level 2
                if found just that just using getCurrentRendererState gave unreliable results so also using set data did what I wanted. ps how do you wrap your code in code?
                if(data){
                return 'critical';
                return 'warning';
                return 'safe';
                return 'safe';
                else{
                return null;
                // TODO Auto Generated method stub
                super.data = value;
                if(data){
                else{
                • 5. Re: I only want state to change when set data is called in GridItemRenderer
                  Yes, you need to put something like this in both set data and getCurrentRendererState().
                  I'm not sure...seems to be a problem on the forums recently with copy/paste.
