0 Replies Latest reply on Nov 17, 2011 7:34 AM by Zolotoj
    Spark datagrid - about Editor size
    Zolotoj Level 3
      I am observing some things related to an item editor.
      It seems to me that the following code gives different results based on an item editor type:
      columns.getItemAt(0, 0).grid.getColumnWidth(0);
      When an item editor, for example, has a dropdown (code simplified):
      ADOBE SYSTEMS INCORPORATED
      Copyright 2010 Adobe Systems Incorporated
      All Rights Reserved.
      NOTICE: Adobe permits you to use, modify, and distribute this file
      in accordance with the terms of the license agreement accompanying it.
      <!--- The ComboBoxGridItemEditor class defines an item renderer for use
      with the Spark grid controls, such as DataGrid and Grid.
      The ComboBoxGridItemEditor  displays a drop-down list of cell values.
      Select a value to set the new value of the cell.
      <p>The following example shows a GridColumn using the ComboBoxGridItemEditor
      as its item editor:</p>
      @see spark.components.DataGrid
      @see spark.components.Grid
      @see spark.components.gridClasses.GridColumn
      @langversion 3.0
      @playerversion Flash 10
      @playerversion AIR 2.5
      @productversion Flex 4.5
      <s:GridItemEditor xmlns:fx="http://ns.adobe.com/mxml/2009"
                        xmlns:mx="library://ns.adobe.com/flex/mx"
                        xmlns:gridEditorClasses="spark.components.gridEditorClasses.*"
          <fx:Script>
              <![CDATA[
                  import mx.binding.utils.BindingUtils;
                  import mx.collections.ArrayCollection;
                  import mx.collections.ArrayList;
                  import mx.collections.IList;
                  import mx.core.IVisualElement;
                  import spark.components.DataGrid;
                  import spark.events.DropDownEvent;
                  //  Overriden properties
                   *  @private
                   *  returns the selected value in the comboBox.
                  override public function get value():Object
                      if (comboBox.selectedItem)
                          return comboBox.selectedItem.value;
                      else
                          return null;
                   *  @private
                   *  Set the selected item of the combo box with the data from the
                   *  item.
                  override public function set value(newValue:Object):void
                      comboBox.selectedItem = newValue;
                  //  Properties
                  //  dataProvider
                  private var _dataProvider:IList;
                  [Bindable("comboBoxGridItemEditorDataProviderChanged")]
                   *  The data provider for the combox box in the item editor.
                   *  @langversion 3.0
                   *  @playerversion Flash 10
                   *  @playerversion AIR 2.5
                   *  @productversion Flex 4.5
                  override public function setFocus():void
                      // delegate focus to the combox box.
                      comboBox.setFocus();
          </fx:Script>
          <!--- @private
          Background to cover the cell that the ComboBox control does not.
          @langversion 3.0
          <!--- The item editor's ComboBox control.
          @langversion 3.0
          <s:DropDownList id="comboBox" width="100%"
      </s:GridItemEditor>
      then the code in question will return correct column width,
      but I use a textArea:
      <s:TextArea id="textArea" fontSize="11" fontFamily="Courier New" width="100%" />
      then the result is wrong - it's smaller then I would expect.
      LIke I said, it seems to me. May be I am iterpreting results wrongly.
      Can someone clarify?
