1 Reply Latest reply on Nov 17, 2011 10:16 AM by GordonSmith
    Compiler questions
    SiHoop Level 1
      What is the name of the compiler used for Flash Builder?
      Does Flash use the same compiler to create a swf or is it different?
        • 1. Re: Compiler questions
          GordonSmith Level 4
          Flash Builder currently uses the "mxmlc" compiler. (In particular a project uses lib\mxmlc.jar inside whichever SDK that project is using. This is the same JAR that the bin\mxml.exe command-line tool in the SDK uses.)
          mxmlc.jar in turn uses asc.jar to do Actionscript compilation.
          I believe Flash also uses asc.jar but doesn't use mxmlc.jar, since it doesn't need to compile MXML.
          Gordon Smith, Adobe
