1 Reply Latest reply on Nov 18, 2011 1:59 PM by kevinklin
    Spark DataGrid with Dynamic Column Width
    bucpatr1 Level 2
      Lets suppose I have a Spark Datagrid with no explicit typicalItem. When the Datagrid is initialized, the column widths are calcualted correctly based on the contents of the dataprovider. However if I add/remove an item from the dataprovider, or modify the one of the objects in the dataprovider, the column widths never update to reflect the change. Is the the correct behavior for a DataGrid? If so, is there any method I can call to force the DataGrid to recalculate and redraw the column widths?
