1. Re: UpdateBook
OliverJohn Nov 18, 2011 3:38 PM (in response to Jason L-S)Short answer first:
var bk = app.ActiveBook;
var updateParams = GetUpdateBookDefaultParams();
var retParams = AllocatePropVals (1);
bk.UpdateBook (updateParams , retParams);
Longer answer:
Learning to wrap your head around "the PropVals thing" is probably the single steepest part of the FM scripting learning curve, esp. if you come from a JavaScript background. The PropVals object is how FM represents many types of property lists.
The object itself is an array of PropVal objects. Each PropVal has two main properties: a propIdent number, which identifies what the property is, and a TypedVal object called propVal, which holds the value for that property.
Each propVal has a property called valType, which identifies a datatype. What other properties the TypedVal has is dependant on the datatype, e.g., sval for strings, ival for signed intergers.
So if we go back to updating your book--we could modify the default parameters to skip updating XRefs like this:
var updateParams = GetUpdateBookDefaultParams();//Returns the array of PropVals
var retParams = AllocatePropVals (1); //"initializes the pointer"
var xProp = GetPropIndex (updateParams, Constants.FS_UpdateBookXRefs);
updateParams[xProp].propVal.ival = false; //ival = 0 would mean the same thing
Several of the other threads on this board can provide more examples of working with PropVals. You can see my struggles with this subject here.
