2 Replies Latest reply on Nov 22, 2011 4:02 PM by Digital_Zephyr
    Setting variable "Frame Delay" for animation.
    Digital_Zephyr Level 1
      I am trying to set frame delay in an animation I am working on. There are a lot of frames and they all have different delays. I am not sure if scripting is the best way but here is what I have so far (using VBA because that is what I am familiar with): I am erroring out at line 23 saying it is a "type mismatch"
      Sub Set_Frame_Delay()
          Dim appPS As Photoshop.Application
          Dim docPS As Photoshop.Document
          Dim NewLay  As Photoshop.ArtLayer
          Dim LaySet As Photoshop.LayerSet
          Dim ref1 As Photoshop.ActionReference
          Dim actPS
          Set appPS = CreateObject("Photoshop.Application")
          appPS.Visible = True
          Set docPS = appPS.ActiveDocument
          Set LaySet = docPS.LayerSets("Text")
          Set ref1 = CreateObject("Photoshop.ActionReference")
          For Each NewLay In LaySet.ArtLayers
                  Select Case NewLay.Name
                  Case "Test1"
                      actPS = ref1.PutName("Frame Delay", 0.540769)
                      NewLay.Application.ExecuteAction (actPS)
                  Case "Test2"
                      actPS = ref1.PutName("Frame Delay", 1.013942)
                End Select
            Next NewLay
          MsgBox "frame set"
      End Sub
        • 1. Re: Setting variable "Frame Delay" for animation.
          Michael L Hale Level 5
          I don't often do much with any flavor of VB. but this looks all wrong to me. For one thing the arguments for putName are not correct. putName requires the class as ID and a string for the name. Your first agrument is a string and your second is a number. However changing that will not help becuase frames don't have names so you can not reference them by name. executeAction requres an actionDescriptor. You are either using an actionReference or just the VBA version of undefined being returned by the putName call. I could go on but I think you can see now that your approach is wrong.
          What I would recommend it that you install the scriptListener plug-in and set the delay of a frame then look in the VB log. You should get something like this.
          REM =======================================================
          DIM objApp
          SET objApp = CreateObject("Photoshop.Application")
          REM Use dialog mode 3 for show no dialogs
          DIM dialogMode
          dialogMode = 3
          DIM idsetd
          idsetd = objApp.CharIDToTypeID( "setd" )
              DIM desc22
              SET desc22 = CreateObject( "Photoshop.ActionDescriptor" )
              DIM idnull
              idnull = objApp.CharIDToTypeID( "null" )
                  DIM ref12
                  SET ref12 = CreateObject( "Photoshop.ActionReference" )
                  DIM idanimationFrameClass
                  idanimationFrameClass = objApp.StringIDToTypeID( "animationFrameClass" )
                  DIM idOrdn
                  idOrdn = objApp.CharIDToTypeID( "Ordn" )
                  DIM idTrgt
                  idTrgt = objApp.CharIDToTypeID( "Trgt" )
                  Call ref12.PutEnumerated( idanimationFrameClass, idOrdn, idTrgt )
              Call desc22.PutReference( idnull, ref12 )
              DIM idT
              idT = objApp.CharIDToTypeID( "T   " )
                  DIM desc23
                  SET desc23 = CreateObject( "Photoshop.ActionDescriptor" )
                  DIM idanimationFrameDelay
                  idanimationFrameDelay = objApp.StringIDToTypeID( "animationFrameDelay" )
                  Call desc23.PutDouble( idanimationFrameDelay, 3.000000 )
              Call desc22.PutObject( idT, idanimationFrameClass, desc23 )
          Call objApp.ExecuteAction( idsetd, desc22, dialogMode )
          I know that is VBS and needs editing to use in VBA but it will give you a better idea of how to construct a executeAction argument.
          • 2. Re: Setting variable "Frame Delay" for animation.
            Yeah Ive used the script listener before, but was hoping to avoid it because I didn't understand everything that it spits out. But I think I broke it down and I came up with below. I tweeked my original solution to use a text file.
            Sub Set_Frame_Delay3()
                Dim ActDescPS1 As Photoshop.ActionDescriptor, ActDescPS2 As Photoshop.ActionDescriptor, ActDescPS3 As Photoshop.ActionDescriptor
                Dim ActRefPS1 As Photoshop.ActionReference, ActRefPS2 As Photoshop.ActionReference
                Dim dialogMode
                Dim idsetd, idnull, idOrdn, idTrgt, idT, idslct
                Dim idAniFrClass, idAniFrDelay
                Dim sFileName As String
                Application.ScreenUpdating = False
                Set appPS = New Photoshop.Application
                dialogMode = 3
                With appPS
                    idsetd = .CharIDToTypeID("setd")
                    idnull = .CharIDToTypeID("null")
                    idOrdn = .CharIDToTypeID("Ordn")
                    idTrgt = .CharIDToTypeID("Trgt")
                    idT = .CharIDToTypeID("T   ")
                    idslct = .CharIDToTypeID("slct")
                    idAniFrClass = .StringIDToTypeID("animationFrameClass")
                    idAniFrDelay = .StringIDToTypeID("animationFrameDelay")
                End With
                sFileName = Application.GetOpenFilename("Textfiles (*.txt),*.txt", , "Open a textfile...")
                oIndex = 0
                iFileNum = FreeFile()
                Open sFileName For Input As iFileNum
                Do While Not EOF(iFileNum)
                    oIndex = oIndex + 1
                    Line Input #iFileNum, oDelay
                    Set ActDescPS1 = New Photoshop.ActionDescriptor
                    Set ActRefPS1 = New Photoshop.ActionReference
                    ActRefPS1.PutIndex idAniFrClass, oIndex
                    ActDescPS1.PutReference idnull, ActRefPS1
                    appPS.ExecuteAction idslct, ActDescPS1, dialogMode
                    Set ActDescPS2 = New Photoshop.ActionDescriptor
                    Set ActRefPS2 = New Photoshop.ActionReference
                    ActRefPS2.PutEnumerated idAniFrClass, idOrdn, idTrgt
                    ActDescPS2.PutReference idnull, ActRefPS2
                    Set ActDescPS3 = New Photoshop.ActionDescriptor
                    ActDescPS3.PutDouble idAniFrDelay, oDelay
                    ActDescPS2.PutObject idT, idAniFrClass, ActDescPS3
                    appPS.ExecuteAction idsetd, ActDescPS2, dialogMode
                    Set ActDescPS1 = Nothing
                    Set ActRefPS1 = Nothing
                    Set ActDescPS2 = Nothing
                    Set ActRefPS2 = Nothing
                    Set ActDescPS3 = Nothing
                Loop
                Application.ScreenUpdating = True
                Set appPS = Nothing
                MsgBox "Frames Delays have been set!"
            End Sub
            The text file only needs to list the times in seconds in order of frames. In case someone else wants to copy the code. Such as :
            0.916303
            0.826175
            0.660941
            1.374455
