0 Replies Latest reply on Nov 19, 2011 10:17 AM by ryancanulla
    [compc] Error: Inconsistant linkage
    ryancanulla Level 1
      Has anyone ran into this issue? I can't find any info on it on the web.
              <compc debug="${DEBUG_FLAG}" output="${CORE_DIR}/bin/launchpad-core.swc"
                          maxmemory="512m" fork="true" >
                  <source-path path-element="${CORE_DIR}/src/" />
                  <include-sources dir="${CORE_DIR}/src" includes="*"/>
                  <library-path dir="${CORE_DIR}/libs" includes="*.swc" append="true"/>
                  <library-path dir="${FLEX_HOME}/frameworks/libs/mobile" includes="*.swc" append="true"/>
                  <library-path dir="${FLEX_HOME}/frameworks/libs/air" includes="*.swc" append="true"/>
                  <library-path dir="${FLEX_HOME}/frameworks/themes/Mobile" includes="*.swc" append="true"/>
                  <compiler.define value="${DEBUG_FLAG}}" name="CONFIG::debug"/>
                  <load-config filename="${FLEX_HOME}/frameworks/flex-config.xml"/>
              </compc>
       [compc]
          [compc] Error: Inconsistant linkage in /Applications/Adobe Flash Builder 4.5/sdks/4.5.1-air-3.0/frameworks/libs/air/airglobal.swc(flash.net.drm:AddToDeviceGroupSetting, flash.net.drm:AuthenticationMethod, flash.net.drm:LoadVoucherSetting) - 'flash.net.drm:LoadVoucherSetting' is marked as extern, but 'flash.net.drm:AddToDeviceGroupSetting' is not.
          [compc]
      BUILD FAILED
      /Volumes/Users/rcanulla/Desktop/aflac-build-server/build.xml:17: compc task failed.
        at flex.ant.FlexTask.executeOutOfProcess(FlexTask.java:256)
        at flex.ant.FlexTask.execute(FlexTask.java:230)
        at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:597)
        at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
        at org.apache.tools.ant.Task.perform(Task.java:348)
        at org.apache.tools.ant.Target.execute(Target.java:390)
        at org.apache.tools.ant.Target.performTasks(Target.java:411)
        at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399)
        at org.apache.tools.ant.Project.executeTarget(Project.java:1368)
        at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
        at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
        at org.apache.tools.ant.Main.runBuild(Main.java:809)
        at org.apache.tools.ant.Main.startAnt(Main.java:217)
        at org.apache.tools.ant.launch.Launcher.run(Launcher.java:280)
        at org.apache.tools.ant.launch.Launcher.main(Launcher.java:109)
      Total time: 40 seconds
