3 Replies Latest reply on Jan 6, 2012 8:32 AM by RGBurghardt
    CFpop and Time Zone
    plarts Level 1
      Sorting by date the mail coming from CFpop, (via a query of query)
      The displayed dateTime is the sender dateTime (from sending location).
      How to get the arrival location dateTime ?
      The variable "date" of cfpop contains the sender dateTime.
      So the order is false because of the Time zone which is different.
      Thanks for any help.
        • 1. Re: CFpop and Time Zone
          plarts Level 1
          I answer myself, cause I found a solution. Here is the code to add a good date/time in the query and sort on it.
          <CFPOP SERVER="#session.mail_server#" USERNAME=#session.UserName# PASSWORD=#session.pwd# ACTION= "GETALL" NAME="all_mails">
             <cfset ldate = ArrayNew(1)>     <!---  for local date/time --->
             <!--- populate the array with local time --->
              <cfloop query="all_mails">
                   <cfset l_date=ParseDateTime(date,"pop")> <!--- CF9 --->
                   <cfset l_date=DateConvert("utc2local", l_date)>
                   <cfset ldate[#currentrow#] = l_date>
               <!--- add a column in the query with a new date field :  l_date  and populate it with the ldate array values --->
             <cfset temp = QueryAddColumn(all_mails, "l_date", "date", ldate)>
             <!--- reorder the query on the new date/time --->
             <cfquery name="GetHeaders_o" dbtype="query"  maxrows="#end_row#">
                   select * from all_mails
                   order by [l_date] desc
          This does work fine for me.
          • 2. Re: CFpop and Time Zone
            plarts Level 1
            Some return on this method :
            The method is good, working, but 2 remarks :
            1 - It would be better that CFPOP could do it itself a sort on dates, because this method takes more time.
                      - a fist loop to rewrite dates in new field : ldate (on all mails)
                      - a second query to reorder (query of query)
            2 - It Happend to me that I get mails without "from" value or "date" value (empty).
                      Then it needs to be verified, and deleted these bad mails during listing.
            Any other remarks or suggestion are welcome.
            • 3. Re: CFpop and Time Zone
              This worked beautifully!  Thank you!!!
