1 Reply Latest reply on Nov 22, 2011 6:40 PM by Subeesh Arakkan
    The height of <mx:RichTextEditor > in VDividedBox cannot be reduced to less than 200.
    Johnking08 Level 1
      I'm using <mx:VDividedBox >, in which there are a mx:RichTextEditor and mx:Image, as in the code below.
      When I dragged the divider of the VDividedBox to resize the heights of the Image and RichTextEditor, I found that the height of the
      RichTextEditor cannot be reduced to less than 200. Is this a bug?
      I replaced RichTextEditor with TextArea, then divider of VDividedBox works fine. I use Flash Builder 4.5. Please try the following code, and
      post you result here. Let's help Adobe to make Flex better.
            xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
      <fx:Script><![CDATA[
        import mx.controls.Alert;
        [Bindable] public var imageSrc:String = "http://cseligman.com/text/sky/perigeeapogee.jpg";
        private function showHeight():void {
         Alert.show(this.rte.height.toString());
      ]]></fx:Script>
        <mx:VDividedBox width="100%" height="100%" >
         <mx:Image id="image_edit" source="{this.imageSrc}" scaleContent="true"
             horizontalAlign="center" verticalAlign="bottom" width="100%" height="100%"
         <mx:RichTextEditor id="rte"
             width="100%"
             text="The Moon.... Click me to show my height." click="showHeight()"/>
        </mx:VDividedBox>
      </s:Application>
