1 Reply Latest reply on Nov 23, 2011 9:44 PM by John Hawkinson
    Updating date and proof number in slug
    JeffLambert Level 1
      Hi, It's been a while, since I worked in applescript. I have a working script that works with a slug that we put at the bottom of our documents. It checks for the proof number and add one if the option is chosen, and it updates the date in a specified cell. I'm looking to better that script and put a dialog that would ask the date, like 0 would be today, 1 would be tomorrow, etc,... and a check mark that would update the proof number or not depending of what the user has choosen.
      Here's my script that works on the current spread. But only puts the current date, with no options to modify it.
      -- Begining of script 1
      (* This is a work in progress to get the date to what ever I want --
      set theNumber to 3
      set theDay to (day of (current date)) as number
      set TheDayValue to theDay + theNumber*)
      set theDay to make_two_digit(day of (current date))
      set theMonth to make_two_digit(month of (current date) as number)
      set theYear to year of (current date)
      set theDate to theYear & "-" & theMonth & "-" & theDay as string
      global theDate
      myDisplayDialog()
      on myDisplayDialog()
                tell application "Adobe InDesign CS5"
                          set myDialog to make dialog with properties {name:"Update Slug"}
                          tell myDialog
                                    tell (make dialog column)
                                              tell (make dialog row)
        make static text with properties {static label:"Options:"}
                                                        end tell
        set myButtons to make radiobutton group
        tell myButtons
        make radiobutton control with properties {static label:"Active Spread: Update date and number", checked state:true}
        make radiobutton control with properties {static label:"Active Spread: Update date only"}
        end tell
                                                        end tell
                                              end tell
                                    end tell
                          end tell
                          set myResult to show myDialog
                          if myResult is true then
                                    set myOption to (selected button of myButtons) + 1
        destroy myDialog
                                    if myOption is 1 then
                                              my UpdateSlugCompleteSpread()
                                    else if myOption is 2 then
                                              my UpdateSlugDateSpread()
                                    end if
                          else
        destroy myDialog
                          end if
                end tell
      end myDisplayDialog
      on UpdateSlugCompleteSpread()
        --Changes the Slug Number and date on the active spread
        --this line is to make it work on the active layer only
                          tell active document
                                    set myLayer to active layer of layout window 1
                                    set myPage to active spread of layout window 1
                                    try
                                              set Slugframe_list to (page items whose name is "SlugFrame") of myPage
                                              repeat with j from 1 to count of Slugframe_list
                                                        set Slugframe to item j of Slugframe_list
                                                        try
        set mynumber to (((text of cell id 11 of table 1 of Slugframe) as string) as number)
        set mynumberText to (mynumber + 1) as string
        --remove the if statement if you need it to be on all layers
        if Slugframe's item layer = myLayer then
        set text of cell id 11 of table 1 of Slugframe to mynumberText
        set text of cell id 16 of table 1 of Slugframe to theDate
        end if
                                                        end try
                                              end repeat
                                    end try
                          end tell
                end tell
        beep
      end UpdateSlugCompleteSpread
      on UpdateSlugDateSpread()
        --Changes the Slug date only on the active spread
        --          try
        --          try
                                              end if
        --end try
                                    end repeat
        --end try
                          end tell
                end tell
        beep
      end UpdateSlugDateSpread
      on make_two_digit(the_number)
                if the_number is less than 10 then
                          set the_result to "0" & the_number as string
                else
                          set the_result to the_number as string
                end if
      end make_two_digit
      --end of script 1
      This is my attempt at modifying the script so far, but I'm stuck. My varialble TheDayvalue gives me an error because it's not define yet, it is but only further in the script and I forgot how to go around that. I know, basic stuff, like I said, it's been a while.
      here's the second script, which doesn't work at all
      --begining of script 2
      set theDay to make_two_digit(day of (current date)) as number
      set theDate to theYear & "-" & theMonth & "-" & theDayValue as string
      global theDateValue
      myDisplayDialog()
                          tell myDialog
        make static text with properties {static label:"Date: 0=Today 1=Tomorrow, etc,..."}
                                                        end tell
        set mydate to make text editbox with properties {edit contents:"0"}
                                                        end tell
        tell myButtons
        end tell
                                                        end tell
                                              end tell
                                    end tell
                          end tell
        --Get the values from the various editboxes.
                                    set myString to (((edit contents of mydate) as string) as number)
                                    set theDayValue to theDay + myString
        destroy myDialog
                                    end if
                          else
        destroy myDialog
                          end if
                end tell
      end myDisplayDialog
                                    try
                                                        try
        end if
                                                        end try
                                              end repeat
                                    end try
                          end tell
                end tell
        beep
        --          try
        --          try
                                              end if
        --end try
                                    end repeat
        --end try
                          end tell
                end tell
        beep
                else
                end if
      end make_two_digit
      --end of script 2
      So, any help in solving this would be greatly appriciated, Thanks!
        • 1. Re: Updating date and proof number in slug
          John Hawkinson Level 5
          Jeff: Your script is too long to reasonably expect people to read and understand. You'll really need to pare your question down into smaller and more manageable chunks. This is probably a good exercise for your learning, anyhow.
          With respect to:
          Well, yes. You cannot use a variable before you define it, scripts execute in order, so this sequence makes no sense:
          The clear answer is to defer setting theDate until after such time as you set theDayValue. That is, move it down in the script. That may necessitate other changes, of course.
          Bite-sized chunks, please. Thanks.
          Happy turkeys.
