9 Replies Latest reply on Dec 28, 2011 5:32 PM by Stephen_Spider
    Single Click registers as Double Click
    FuelMe Level 1
      Hi guys, my current issue is a bit hard to explain but here goes:...
      In CS 5.5 I now have an issue where a single mouse click is often registered as a double-click. This means if, for example, if I single-click on a clip that is placed on the timeline to select it and want to drag or trim, Premiere registers it as a double click and opens up the clip in a Source Monitor. This gets old really fast. There are a lot of other instances where Premiere does this and I need it to stop.
      I'm suspecting a possible issue with the graphic card (GTX580), however it worked flawlessly, no mods or driver changes have been done.
      I played around with the Windows mouse settings hoping it would fix it, but to no avail. I tried different mice, from a cabled cheap Dell mouse to a wireless Microsoft mouse. No changes. Restarts or creating new Projects didn't help. No new peripherals have been added, and no upgrades or registry changes have been made.
      Any ideas?
      Thank you
      Win 7 Pro
      Core i7 980X  (not overclocked)
      24 GB 1333 Mhz Memory
      GTX 580
      120 GB SSD - Boot
      400 GB Velociraptor - Caches
      1 TB WD Cav Black - Sources
      1 TB WD Cav Black - Finished Work
      60 GB SSD - Projects/Swap
