3 Replies Latest reply: Dec 2, 2011 12:35 PM by reindeer4 RSS
    Video not displaying properly and not exporting.
    reindeer4 Community Member
      I'm using Premiere Pro CS4 and After Effects CS4.  I brought an AFX composition in via Dynamic Link, made copies of the clip, chopped it up and spliced it back together on one video layer.  Within the Premiere Pro interface, the video shows up normally when I hit play.  If I hit stop, however, the display area just shows black instead of an image (and if I click any blend mode other than Normal, the image shows up until I move the CTI at which point it disappears again).
      Upon trying Export Media, I don't get any video -just a black screen along with the audio.
      My eyeball is set to on for visible, opacity is 100%, and non other video layers are turned on.
      Not sure what's wrong or how to fix it.
      Thanks for any help.
        • 1. Re: Video not displaying properly and not exporting.
          Still getting similar problems.  This time I have a dynamic link to one complicated AFX CS4 precomp which lasts for about 4 minutes.  Barely plays inside of Premiere; when I hit play, the video will start but it quickly just stays on the same video frame while the audio plays.  If I hit stop and then play again, it will advance to a new frame where the CTI is and then freeze there.
          I tried pre-rendering a few seconds inside of Premiere, and now that part is solid black when I hit play - and when the CTI gets past that section, it goes back to displaying video briefly till it freezes on a new frame again.
          Using Windows Task Manager, Premiere Pro is using between1-2 GB RAM, and After Effects close to 3GB RAM - and I'm guessing that's my problem since these are only 32 bit programs (even though I'm on Windows 7 with 24GB RAM).
          If anyone can confirm whether that's the likely problem or suggest a workaround I'd appreciate it.
          May try a trial of the 64 bit programs to see if that fixes things.  Had downloaded AFX and Premiere Pro separately, but don't get dynamic link that way so may have to look at the suites.
          • 2. Re: Video not displaying properly and not exporting.
            Community Member
            dont know for certain ..you would need to supply more info about your platform ... but sometimes visual problems ( playback on program monitor etc and black stuff ) is relelated to video graphics card. do you have latest drivers for that card etc?? go to card OEM for latest drivers..
            otherwise youll need to supply more info about a lot of stuff to help others help you
            note:
            is there a way to run legacy programs on your 64 bit os ??? think i read something about that... like help make 32 bit programs more friendly to newer machines. etc?
            thats just another idea.
            • 3. Re: Video not displaying properly and not exporting.
              thanks able123 -
              My video card's drivers were pretty out of date, and updating them did help with previewing things more smoothly, though the overall problem still remained.  Upon downloading trial versions of the 64bit programs the problem went away - so I'm guessing it had to do with running out of memory in the 32bit programs.  (and to answer your question, there's no problem running 'legacy' 32 bit programs on my system - indeed, except for Photoshop, all of my Adobe programs are 32 bit.
