2 Replies Latest reply on Nov 22, 2011 12:11 PM by Jeremy Tan
    cfdocument srcfile case issue
    Jeremy Tan
      Recently we start using coldfusion 9 and open office to convert office file to PDF, then we come across a very strange issue.
      <cfset myDoc = "C:\my.DOC">
      <cfdocument format="pdf" srcfile="#LCASE(myDoc)# filename="#myDoc#-a.pdf"></cfdocument>
      <cfdocument format="pdf" srcfile="#myDoc# filename="#myDoc#-b.pdf"></cfdocument>
      The output of C:\my.DOC-a.pdf is unreable (binary content) but C:\my.DOC-b.pdf is fine
      Anyone have this problem?
      Coldfusion version is 9,0,1,274733
        • 1. Re: cfdocument srcfile case issue
          insuractive Level 3
          What OS is your server running on?
          • 2. Re: cfdocument srcfile case issue
            Jeremy Tan Level 1
            Sorry, I have the wrong order in my first post.
            The output for the one with lower case extention is fine
            The output for the one with upper case extention is unreadable (binary content)
            I also tried to use mimetype application/msword, coldfusion crash when having upper case extention
            An exception occurred when performing document processing.
            The cause of this exception was that: coldfusion.document.spi.DocumentExportException: java.lang.RuntimeException: The document is not open."
            The server is having:
            Windows Server 2008 R2 Standards and
            Same problem happen on
            Windows 7 Ultimate and
