1 Reply Latest reply on Dec 15, 2011 6:12 AM by Stewartg33k
    Flash Builder 4.5 and SOAPHeader operation problem.
    Stewartg33k Level 1
      I have been working on this for the last couple days and I have not been able to come up with a solution.  Anyone out there have any suggestions.
      I am trying to consume a Web service and it requires an Authentication Header.  I know the web services works by other means.  I would like to use the auto generated code, but it does not seem to want to add the authheader.
      I have tried the following forum links to no avail.
      http://forums.adobe.com/message/3069512
      http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/mx/rpc/soap/Operation.h tml#addHeader%28%29
      Here is the function I am calling.
      public function headers():void {
      var header1:SOAPHeader;
      var obj:Object = new Object;
      obj.Username = "XXX";
      obj.Password = "YYY";
      // Create QName and SOAPHeader objects.
      var q1:QName=new QName("http://www.server.com/yadda/yadda", "AuthHeader");
      header1=new SOAPHeader(q1, obj);
      // Add the Authentication SOAP Header to all web service request.
      operations["GetCommand"].addHeader(header1);
      operations["SetCommand"].addHeader(header1);
      When I debug this I can see that all the information is in it's correct place, however when I wireshark the actual communication I get the following.
      <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:s="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
        <SOAP-ENV:Header>
          <tns:AuthHeader xmlns:tns="http://www.server.com/yadda/yadda"/>
        </SOAP-ENV:Header>
        <SOAP-ENV:Body>
          <tns:GetCommand xmlns:tns="http://www.server.com/yadda/yadda">
            <tns:value1></tns:value1>
            <tns:value2></tns:value2>
          </tns:GetCommand>
        </SOAP-ENV:Body>
      </SOAP-ENV:Envelope>
      So I am getting the AuthHeader and the QName added, just not the username and password vaules.   Any ideas on what I am doing wrong?
      -Stewart
        • 1. Re: Flash Builder 4.5 and SOAPHeader operation problem.
          Stewartg33k Level 1
          I did get this to work.  If you do the following in the action script file that has the preinitialization fuction.  The header gets added properly.
          This gets initalized on the load of the application.  I would really like to be able to set the username and password with a login box.  However, since this loads on launch I have not been able to get the values into the header.  Does anyone know how you can refresh this operation to reflect the changes in the values?  I know the values are getting set in my Login.as, but I can not find anything on how to reload the webservice to pick up the change in values.
                  import mx.rpc.soap.SOAPHeader;
                  _serviceControl.addHeader(header1);
          -Stewart
