3 Replies Latest reply on Nov 23, 2011 11:05 AM by andymarsha11
    Finished video is flashing
    andymarsha11
      Just edited a video in Elements Prem iere 10, for some reason when the video is played back there is a constant flashing within the graphics. I have tried this several times saving in different formats to no avail. The problems is I spent weeks on this project within premeire elements 9 then upgraded to 10, opened my project in prem 10 and had problem ever since. I cant open project in perm 9 anymore as its states unregonizable format? Any help or information would be welcome?
      Is there an issue wqith opening projects from v9 into v10
        • 1. Re: Finished video is flashing
          This is why we always recommend against opening an older version project with a newer version of the program -- or at least saving a copy of the original if you do. This kind of buggy behavior is pretty common.
          That said...
          It's only the graphics that are flashing?
          What are these graphics? Are they text or do they take up an entire video frame, like a slide? What program were they created in and how are they used?
          Have you tried applying de-interlacing to them.
          • 2. Re: Finished video is flashing
            the_wine_snob Level 9
            Did you apply any of the "Auto" Effects to the Clips? With varying lighting, many can cause "strobing."
            In the meantime, can you tell us a few things:
            • The Project Preset chosen at New Project?
            • The Source Footage?
            • Any Effects used?
            • Desired Export/Share format?
            • Where you are seeing this "flashing" such as when played in WMP?
            • 3. Re: Finished video is flashing
              andymarsha11 Level 1
              The whole video from start to finish is flashing, there are many clips of stills and video footage which comprises of a 15 minute movie I have been working on. All was fine until I started using Premiere Elements 10. I havent used any effects, other than cross fade transitions from one clip to another. I am using a Canon HF200 as the source using a preset NTSC AVCHD which the Canon is a NTSC camera. I am exporting into Blu Ray, but tried sveral formats but its still the same. I have burnt a disc and the strobing / flashing is the same when played back on tv
