10 Replies Latest reply on Nov 23, 2011 10:19 PM by drkstr_1
    Is this possible with Actionscript 3 events?
    Rick.Blacker
      Fairly new to AS3. Studying up on events.
      Is it possible to have a simple value object dispatch an event and have the script inside the MXML respond to that event itself without having to register the event on the value object itself?
      Example of what I'm talking about
      I have a simple value object named Person. Not directly inherited from anything.
      Has one variable.  firstName : String;
      When the firstName variable gets changed, the setter creates a new DispatchEvent object and dispatches a new event. It does this without any runtime errors.  Back in the MXML, I want the MXML's Application to be what registers the event, NOT the Person object. In fact, it can't because I didn't inhert from the DispatchEvent class.
      I've provided both the custom class and the MXML. I've kept it as bare bones and as simplistic as possible to get my intent across.
      MY CUSTOM CLASS DEFINITION
      package myClasses
      import flash.events.Event;
      import flash.events.EventDispatcher;
      public class Person
        private var _firstName : String;
        public function Person( fName : String )
         _firstName = fName;
        [Bindable(event="firstNameChange")]
        public function get firstName():String
         return _firstName;
        public function set firstName(value:String):void
         if( _firstName !== value)
          _firstName = value;
          var d:EventDispatcher = new EventDispatcher( );
          d.dispatchEvent( new Event( "firstNameChange" ) );
      MY MXML
            xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
            creationComplete="application1_creationCompleteHandler(event)">
      <fx:Script>
        <![CDATA[
         import mx.controls.Alert;
         import mx.events.FlexEvent;
         import myClasses.Person;
         [Bindable]
         protected var myPerson:Person
         protected function application1_creationCompleteHandler(event:FlexEvent):void
           // Want the "application" to be notified when the "firstNameChange" event happens
          addEventListener( "firstNameChange", personChanged );
          myPerson = new Person( "Scoobie Do" );
          // Force a change and HOPE the event triggers
          myPerson.firstName = "Shaggy";
           // This is NOT being ran.
         protected function personChanged( e:Event ) : void
          Alert.show( "triggered" );
      </fx:Script>
      </s:Application>
      All the examples I've seen would have the Person class inherit from the DispatchEvent class, then back in the MXML you'd have something like this
      var p:Person = new Person( "thelma" );
      p.addEventListener( "firstNameChange", someEventHandlerFunction );
      I get that, but not what I'm trying to acheive here. I just want the Person object to dispatch the event and have someone else be able to listen for the "firstNameChange" event.   Is this possible?
      Thanks for the help!!!!
