4 Replies Latest reply on Nov 22, 2011 8:21 PM by LCamp11
    CS5 isn't importing complete .avi files
    LCamp11
      I imported several .avi files into a project, and so far two of them will not play completely in CS5. i.e.- one file is 00:10:23, but in CS5, it only imported the first 3 minutes, and 14 seconds. Th whole clip imports correctly if I throw it into CS3 or watch it on Windows Media Player.
      Any assistance is appreciated.
        • 1. Re: CS5 isn't importing complete .avi files
          Colin Brougham Level 6
          What codec is in the AVI? Something like Xvid? Grab MediaInfo and use it to look at one of the files; post a report here from Text mode.
          • 2. Re: CS5 isn't importing complete .avi files
            LCamp11 Level 1
            Here you go:
            General
            CompleteName                : C:\Users\Suarez\Suarezbackup\SuarezInt-001.avi
            Format                           : AVI
            Format/Info                      : Audio Video Interleave
            Format_Profile                   : OpenDML
            FileSize/String                  : 4.02 GiB
            Duration/String                  : 10mn 23s
            OverallBitRate/String            : 55.4 Mbps
            Video
            ID/String                        : 0
            Format                           : CineForm
            CodecID                          : CFHD
            CodecID/Info                     : CineForm 10-bit Visually Perfect HD (Wavelet)
            BitRate/String                   : 53.6 Mbps
            Width/String                     : 1 440 pixels
            Height/String                    : 1 080 pixels
            DisplayAspectRatio/String        : 4:3
            FrameRate/String                 : 23.976 fps
            ScanType/String                  : Progressive
            Bits-(Pixel*Frame)               : 1.437
            StreamSize/String                : 3.89 GiB (97%)
            Audio
            ID/String                        : 1
            Format                           : PCM
            Format_Settings_Endianness       : Little
            Format_Settings_Sign             : Signed
            CodecID                          : 1
            Duration/String                  : 10mn 22s
            BitRate_Mode/String              : Constant
            BitRate/String                   : 1 536 Kbps
            Channel(s)/String                : 2 channels
            SamplingRate/String              : 48.0 KHz
            BitDepth/String                  : 16 bits
            StreamSize/String                : 114 MiB (3%)
            Interleave_Duration/String       : 24 ms (0.58 video frame)
            Interleave_Preload/String        : 480 ms
            • 3. Re: CS5 isn't importing complete .avi files
              So, I'm assuming that you do have Cineform installed, since you're able to playback the files at least partially? Do you have an updated version of the codec/decoder?
              • 4. Re: CS5 isn't importing complete .avi files
                LCamp11 Level 1
                Yes, I updated Cineform before I imported the files. And so far it's only done this with two files. The other file is 09:22, but only 02:12 shows up in Premiere.
