8 Replies Latest reply: Nov 24, 2011 1:56 AM by MehulJSheth RSS
    Can SDK be used to edit PDF data?
    MehulJSheth Community Member
            As what i know Acrobat SDK can be used to deal with Pdf. My application demands to edit pdf data without changing format, structure, layout etc from the source doc. I just need to modify the content. So i want to read pdf doc from beginning, extract text(either paragrapgh or statement wise), modify if needed and put them back. Is it possible with SDK? Also as what i know PDF Library SDK is not available for even trial version so how can i check it whether it satisfies my need or not before going for commercial version. Is there any other SDK which i can use that helps me with the scinario i explained.
      Mehul
