1 Reply Latest reply on Nov 24, 2011 8:11 AM by John Hall
    problem in using action script component in Flash Builder 4.5 ...
    asifdegr8 Level 1
      I am using following open source action script component
      http://joshblog.net/2007/09/16/open-source-flex-components-advancedlist-and-checkboxlist/# comment-21358
      I used this component in Flex 3 and Flash Builder 4.0, it works fine. But When I used this in Flash Builder 4.5 like
      <toolbox:CheckBoxList id="checkList" />
      It do not allow to set its id property, rest all other properties can be set. It gives following error.
      1046: Type was not found or was not a compile-time constant: CheckBoxList
        • 1. Re: problem in using action script component in Flash Builder 4.5 ...
          John Hall Level 4
          Worked OK for me, though the namespace works out a little differently for me in that the control is bound to xmlns:controls="com.flextoolbox.controls.*", making my mxml tag
          <controls:CheckBoxList id="test" />
          You might insert a new checkboxlist above the current line and make sure it still comes up in the toolbox namespace. If not, just finish typing that new one and it will bind the namespace, then you can use that line instead of the old one.
