3 Replies Latest reply on Nov 25, 2011 9:39 AM by kglad
    Hittest Not Working
    olafgarten212
      This is my code it is not working
      on (keyPress "<Left>") {
           currentX = this._x;
           this._x = currentX - 5;
      if(this.hitTest(_root.leftbord)) { this._y++; }
      on (keyPress "<Right>") {
           currentX = this._x;
           this._x = currentX + 5;
           if(this.hitTest(_root.rightbord)) { this._y--; }
        • 1. Re: Hittest Not Working
          If I try the code it does what the code says to do, so what aspect of it is not working for you?  Have you assigned the instance names you use to the objects you are hitTest-ing?
          • 2. Re: Hittest Not Working
            olafgarten212 Level 1
            when i crash into the wall i walk right past it and i have set the instance name
            • 3. Re: Hittest Not Working
              that's what you've coded:  when you're using the left key and hit "this", you move to the left and when using the right key, you move to the right.
              if you want to rebound use:
                   currentX = this._x;
                   currentX = this._x;
