0 Replies Latest reply on Nov 23, 2011 5:17 PM by Donal K.
    Premiere CS5, DPX import and EDL export
    Donal K.
      Hello,
      this is my first encounted with editing DPX files in Premiere, I've only exported projects to DPX so have a few problems. I received DPX files for editing and expected to return EDL. I've imported the DPX into Premiere as a sequence and edited the project - the problem comes is when I check the exported EDL - if I import the finished EDL all the clips on the timeline are not connected to the media; when I try to reconnect them, they end up pointing to the first frame because I can only select one DPX as opposed to the whole DPX sequence option. I've tried to import DPX file separately and recreated clips and cuts in the timeline - when I export that, bizzare thing happens - the finished EDL has all the files in reverse from start to the end... Sending the whole project to AE and exporting DPX was the last option because I wanted to find a way to export it from Premiere.
      What is the correct workflow for editing DPX files in Premiere and exporting EDL?
      Thanks in advance,
      D.
