3 Replies Latest reply on Nov 29, 2011 11:59 PM by amitKumarKanda
    error in compile
    amitKumarKanda Level 1
      Hello,
      I have a flash application built in flash cs5 and action script 3.0. When i try to compile it, it returns error.
      , Line 15005: Unknown error optimizing byte code.
      or
      ReferenceError: Error #1065: Variable UIProperties_icon is not defined.
      I have converted this to air android application. Now i am getting one of these message every time when i compile or try to make apk file.
      Somebody please suggest a solution for this.
      Thanks----------Amit
        • 1. Re: error in compile
          dmeN Level 5
          It seems this error is mostly due to large files... which doesn't really fit in with making an Android app. Is your file really large? From what I read you can try deleting aso files (control menu > delete ASO files). Otherwise you can try turning off the optimizer also - publish settings - flash tab - uncheck compress movie.
          You can find out some more on this by Googling 'as3 5005 error'
          • 2. Re: error in compile
            Hello Dmenneoh,
            Thanks for your response.
            I have tried with both the options and tried on google but did not any solution for the problem. My fla file is of 2 mb and it is using lots of components.
            Thanks-----------------Amit
            • 3. Re: error in compile
              Thanks Dmenneoh, I am able to generate the file after following change.
              D:\Program Files\Adobe\Adobe Flash CS5\Common\First Run\ActionScript 3.0\jvm.ini file I have set -Xmx128m to -Xmx1024m.
              This compile the file.
              Thanks --- Amit
