8 Replies Latest reply on Dec 4, 2011 9:23 AM by armandix
    generate a drop down menu in action script 1
    armandix
      hello people ,
      I developed a menu and it loads a xml, now I'm trying to convert it to work with php and mysql.
      But I encountered a problem the flash will not load data that comes from mysql db.
      this is my menu AS code:
      gerar_menu = function(container, name, x, y, depth, node_xml){
                //declarar variaves
                var corrent_node;
                var corrent_item;
                var corrent_menu = container.createEmptyMovieClip(name, depth);
                for(var i=0; i< node_xml.childNodes.length; i++){
                          //um movie clip para cada item de menu
                          //attacheMovie(agrega o movieclip da livraria, novo nome dado pelo utilizador, ++ incremento);
                          corrent_item = corrent_menu.attachMovie("menuit","menu"+i+"_mc", i);
                          corrent_item._x = x + i*corrent_item._width;
                          corrent_item._y = y;
                          corrent_item.trackAsMenu = true;
                          // propriedades provenientes do XML
                          corrent_node = node_xml.childNodes[i];
                          corrent_item.action = corrent_node.attributes.action;
                          corrent_item.variables = corrent_node.attributes.variables;
                          corrent_item.name.text = corrent_node.attributes.name;
                          trace(corrent_node);
                          if (node_xml.childNodes[i].nodeName == "menu"){
                                    //abre o submenu
                                    corrent_item.node_xml = corrent_node;
                                    corrent_item.onRollOver = corrent_item.onDragOver  = function(){
                                    /*aqui meter as posições onde queres que as posicione*/
                                    var px = this._x;
                                    var py = this._y + this._height +2;
                                    // gerar submenu
                                    gerar_menu(corrent_menu, "submenu_mc", px, py, 1000, this.node_xml);
                                    var cor =new Color(this.background);
                                    cor.setRGB(0x767676);
                                    trace("enra");
                }else{
                          // caso não exista submenu esconde a seta
                          corrent_menu.submenu_mc.removeMovieClip();
                //fim do else
                          corrent_item.onRollOut = corrent_item.onDragOut  = function(){
                          cor.setTransform({ra:100,rb:0,ga:100,gb:0,ba:100,bb:0});
                          corrent_item.submenu_mc.onRollOut = corrent_item.submenu_mc.onDragOut  = function(){
                          CloseSubmenus();
                          //qualquer menu em aberto ou a executar uma acção
                          corrent_item.onRelease = function(){
                          Actions[this.action](this.variables);
                          CloseSubmenus();
      }//fim do loop;
      // criar um menu com posição determinnada
      criar_menu = function(x, y, depth, menu_xml){
                gerar_menu(this, "mainmenu_mc", x, y, depth, menu_xml.firstChild);
      // fechar unicaexclusivamente os submenus caso estejam abertos
      // a inatncia mainmenu_mc continua
      mainmenu_mc.onMouseUp = function(){
                          if (mainmenu_mc.submenu_mc && !mainmenu_mc.hitTest(_root._xmouse, _root._ymouse, true)){
                                    CloseSubmenus();
      CloseSubmenus = function(){
                mainmenu_mc.submenu_mc.removeMovieClip();
      //estas acções determinão metodos para estes objectos
      Actions = Object();
      Actions.gotoURL = function(urlVar){
      getURL(urlVar, "_blank");
      Actions.message = function(msg){
      message_txt.text = msg;
      Actions.newMenu = function(menuxml){
      menu_xml.load(menuxml);
      //carrega o XML e , cria o MainMenu para o interpretar
      menu_xml = new XML();
      menu_xml.ignoreWhite = true;
      menu_xml.onLoad = function(ok){
                //caso o xml seja carregado com sucesso carrega o menu na posição
                if (ok){
                                              criar_menu(160, 50, 0, this);
                          message_txt.text = "message area";
                }else{
                          message_txt.text = "error:  XML not successfully loaded";
      // carrega primeiro o menu.xml em que lang determina a linguagem que ira carregar
      menu_xml.load("menu"+_root.lang+".php");
      And this is my php code:
      <?php
      $link =mysql_connect("localhost","brigansol","@brigansol@");
      mysql_select_db("brigansol");
      echo"<?xml version=\"1.0\" encoding=\"ISO-8859-1\"?>\n";
      $query="SELECT * FROM tbl_categorias ORDER BY categoria_pt ASC";
      $resultado = mysql_query($query);
      while($row = mysql_fetch_array($resultado)) {
      echo"<menu name='".$row['categoria_pt']."'>\n";
      $query1="SELECT tbl_categorias.id_categorias, tbl_categorias.categoria_pt, tbl_subcategorias.id_subcategorias, tbl_subcategorias.categorias_id, tbl_subcategorias.subcategoria_pt, tbl_subcategorias.referencia FROM tbl_categorias JOIN tbl_subcategorias WHERE tbl_categorias.id_categorias = tbl_subcategorias.categorias_id AND tbl_subcategorias.categorias_id =".$row['id_categorias']." ORDER BY tbl_subcategorias.subcategoria_pt ASC";
      $resultado1 = mysql_query($query1);
      while($row1 = mysql_fetch_array($resultado1)) {
      echo"<item name='".$row1['subcategoria_pt']."' action='' variables=''></item>\n";
      echo"</menu>\n";
      mysql_close($link);
        • 1. Re: generate a drop down menu in action script 1
          are you really publishing for as1?  if yes, is this a mobile app that needs to use flashlite?
          for what flash player version are you publishing?
          • 2. Re: generate a drop down menu in action script 1
            armandix Level 1
            flash 9 action script 1.No is a menu for a website.
            • 3. Re: generate a drop down menu in action script 1
              why aren't you publishing for as2, then?  you should change your publish settings and retest.
              • 4. Re: generate a drop down menu in action script 1
                armandix Level 1
                I've tried everything , but does not work. I am creating an app that works locally as a catalog
                • 5. Re: generate a drop down menu in action script 1
                  using as2 publish settings, what's the first problem?
                  • 6. Re: generate a drop down menu in action script 1
                    armandix Level 1
                    Let me explain my project...
                    I am creating a catalog, and I need to create a menu that load dynamically with data from the db.
                    My biggest problem is:
                    To load data from db using php to create xml file dynamically, but the flash does not readbeyond the tag for "<?Php ?>"
                    I'll post some screenshots of my work.
                    without php:
                    with php:
                    • 7. Re: generate a drop down menu in action script 1
                      use the onData method instead of the onLoad and view the return from your php to see if you have an error begin returned.
                      • 8. Re: generate a drop down menu in action script 1
                        armandix Level 1
                        Kglad , tanks for your help!
                        I ready solved the problem. But a new problem appeared.
                        between this code lines:
                                                      //abre o submenu
                                                      var px = this._x;
                                                      // gerar submenu
                                                      trace("enra");
                        I need correct a problem and make every parent node shows the childrens nodes...
                        with these changes is to repeat several times the main menu
                        I'll post some screenshots Flash project :
                        xml :
