This content has been marked as final.
Show 4 replies
1. Re: Fix timecode offset from secondary audio device
Rover965 Nov 28, 2011 6:01 PM (in response to Rover965)Gee, that was pretty easy...figured it out after some poking around. Right-click on the audio file that needs the timecode adjusted, select Modify then Timecode, then click on the yellow timecode display in the popup window and adjust accordingly (in my case, adjusting by 10 frames).
2. Re: Fix timecode offset from secondary audio device
JSS1138 Nov 28, 2011 8:19 PM (in response to Rover965)It's constant (no drift)
What device?
3. Re: Fix timecode offset from secondary audio device
Rover965 Nov 28, 2011 9:33 PM (in response to JSS1138) -
4. Re: Fix timecode offset from secondary audio device
JSS1138 Nov 29, 2011 9:46 AM (in response to Rover965)Thanks.
