0 Replies Latest reply on Nov 29, 2011 1:38 AM by SureshVytla
    AdvancedDataGrid custom summary row on top
    SureshVytla Level 1
      Hi All,
           I have flex advanced data grid (hierarchal) with custom summary row. I have used the concept of Dynamic Advanced List (http://active.tutsplus.com/tutorials/flex/dynamic-advanced-long-lists-with-flex/)
      I have a custom summary row that is positioned as footer. This works fine without any issues.
          I have a requirement to show the custom summary row as a top row (locked row) in the advanced data grid. I have managed to position the the custom summary row top of the grid. I put dummy object for the first row in data grid and positioned the summary row after grid header row.
      The problem I have is when we scroll the rows in the data grid the summary row content is overlapping with grid rows.
          Is there anyway that I can manage to hide the scrollable content in the advanced data grid?
         in adjustListContent I am positioning footer after header row by
      override protected function adjustListContent(unscaledWidth:Number = -1, unscaledHeight:Number = -1):void
                                    super.adjustListContent(unscaledWidth, unscaledHeight);
                                    listContent.setActualSize(listContent.width, listContent.height);
                                    footer.setActualSize(listContent.width, footerHeight);
                                    //footer.move(listContent.x, listContent.y + listContent.height + 1);
                                    footer.move(listContent.x, this.headerHeight + 1);
        Here footer is custom class extends UIComponent (AdvancedDataGridFooter)
      public class AdvancedDataGridFooter extends UIComponent
                private var colAlignmentSet:Set;
                public function AdvancedDataGridFooter(colAlignmentSet:Set)
                          super();
                          this.colAlignmentSet = colAlignmentSet;
                protected var overlayFixed:Sprite;
                protected var overlayScrollable:Sprite;
                protected var dataGrid:AdvancedDataGrid;
                 *  create the actual border here
                override protected function createChildren():void
                          dataGrid = parent as AdvancedDataGrid;
                          overlayFixed = new Sprite();
                          addChild(overlayFixed);
                          overlayScrollable = new Sprite();
                          addChild(overlayScrollable);
                          dataGrid.addEventListener(AdvancedDataGridEvent.COLUMN_STRETCH,
                                    _handleColumnStretch);
                private function _handleColumnStretch (e : AdvancedDataGridEvent) : void {
                          _drawFixedColumns = false;
                //you only need to draw the fixed columns on init and when the columns
                //are resized
                private var _drawFixedColumns : Boolean = false;
                 *          lay it out
                override protected function updateDisplayList(w:Number, h:Number):void
                          overlayScrollable.graphics.clear();
                          if (!_drawFixedColumns){
                              overlayFixed.graphics.clear();
                      var lockedColumns : int = dataGrid.lockedColumnCount;
                          // destroy the old children - except the grid lines and the mask
                          // if there is no mask, only keep the the grid lines (level 0),
                          // if there is a mask, keep mask (level 0) and grid lines (level 1)
                          var childrenToKeep : int = 2;
                          if (_drawFixedColumns) childrenToKeep += lockedColumns;
                          if (dataGrid.getStyle("horizontalScrollPolicy") != "off") {
                                    childrenToKeep ++;
                                    _updateMask (w, h);
                          while (numChildren > childrenToKeep) removeChildAt(childrenToKeep);
                          // make new ones
                          var cols:Array = dataGrid.columns;
                if(null != cols && cols.length > 0){
            var lineCol:uint = dataGrid.getStyle("verticalGridLineColor");
            var vlines:Boolean = dataGrid.getStyle("verticalGridLines");
                          overlayFixed.graphics.lineStyle(1, lineCol);
                          overlayScrollable.graphics.lineStyle(1, lineCol);
                          var xx:Number = 0;
                          var yy:Number = 0;
                          var i : int = 0;
                          var col:AdvancedDataGridColumn;
                          //draw the locked columns if there are any
                          while (xx < w && i < lockedColumns)
                                    col = cols[i++];
               if (!_drawFixedColumns) {
                                        _drawColumn(col, overlayFixed, i, xx, yy, h);
                                    xx += col.width;
                          _drawFixedColumns = true;
                          //draw the scrollable columns
                          i = dataGrid.horizontalScrollPosition + lockedColumns;
                          while (xx < w && i < cols.length )
                                    col = cols[i++];
                                    _drawColumn(col, overlayScrollable, i, xx, yy, h);
                                    xx += col.width;
            lineCol = dataGrid.getStyle("horizontalGridLineColor");
            if (dataGrid.getStyle("horizontalGridLines")) {
                                    overlayFixed.graphics.moveTo(0, yy);
                                    overlayFixed.graphics.lineTo(w, yy);
                          // draw separator at top of footer
            lineCol = dataGrid.getStyle("borderColor");
                          overlayFixed.graphics.moveTo(0, 0);
                          overlayFixed.graphics.lineTo(w, 0);
                private function _drawColumn (col:AdvancedDataGridColumn,
                    drawSprite : Sprite, i : int, xx : Number, yy : Number, h : Number) :
                    void
                    if (col is FooterAdvancedDataGridColumn) {
                                    var fdgc:FooterAdvancedDataGridColumn = col as
                                        FooterAdvancedDataGridColumn;
                                    fdgc.footerColumn.owner = fdgc.owner;
                                    var renderer:IListItemRenderer = (fdgc.footerColumn.itemRenderer) ?
                                              fdgc.footerColumn.itemRenderer.newInstance() :
                                              dataGrid.itemRenderer.newInstance();
                                    if(this.colAlignmentSet.contains(col.dataField)){
                                              renderer.styleName = "summaryRightStyle";
                                    }else{
                                              renderer.styleName = "summaryLeftStyle";
                                    //if(col.dataField != "key"){
                                              //renderer.styleName = "summaryStyle";
                                    if (renderer is IDropInListItemRenderer) {
                                              IDropInListItemRenderer(renderer).listData =
                                                        new AdvancedDataGridListData(
                                                        (fdgc.footerColumn.labelFunction != null) ?
                                   fdgc.footerColumn.labelFunction(col)
                                                        : fdgc.footerColumn.headerText,
                                                        fdgc.dataField, i - 1, null, dataGrid, -1);
                                    renderer.data = fdgc;
                                    addChild(DisplayObject(renderer));
                                    renderer.x = xx;
                                    renderer.y = yy;
                                    renderer.setActualSize(col.width - 1, dataGrid.rowHeight);
                                    if (dataGrid.getStyle("verticalGridLines"))
                                              drawSprite.graphics.moveTo(xx + col.width, yy);
                                              drawSprite.graphics.lineTo(xx + col.width, h);
                private var _myMask : Sprite;
                 * Does two things : creates the mask if it's needed
                 * Updates the mask size based on the new size properties
                private function _updateMask (w : Number, h : Number) : void {
                          //if the mask hasn't been created, create it
                          if (_myMask == null) {
                                    _myMask = new Sprite();
                                    //need to add it at 1 because horizontal scroll policy could
                                    //change at run time, and the removal of the text is based on
                                    //child index
                                    addChildAt(_myMask, 1);
                                    mask = _myMask;
                          var g : Graphics = _myMask.graphics;
                          g.clear();
                          g.beginFill(0xffffff, 0);
                          g.drawRect(0, 0, w, h);
                          g.endFill();
      Suresh
