2 Replies Latest reply on Nov 29, 2011 5:41 AM by Loic.Aigon
    ScriptUI and weird Object behaviour
    Loic.Aigon Adobe Community Professional
      I am working on a galaxy of little helpers that all share a same scriptUI dialog script (include). I have included an option to add window components from the helper thanks to a function:
      function ExtraUIItems(parentContainer){
           //Adding UI elements
           this.getItem = function(){
                return {
                     choice:"a",
                     style:"b"
      so in the scriptUI general code, I check for a flag and add item if needed :
      var extraItems = new ExtraUIItems(w);
      and then when I need datas, I call the getItem function
      extraItems.getItem();
      Problem is :
      extraItems.getItem().style //"b" => OK
      extraItems.getItem().choice //undefined
      //and
      extraItems.getItem().toSource() // {style:"b"} => no evidence of choice property
      //If I mistype style on purpose, ask for toSource() again,  and rerun the script
      extraItems.getItem().toSource() //{} => No properties at all
      I thought about initialization but even restarting InDesign doesn't solve it .
      My question is : WTH Am I doing wrong ?
      TIA
      Loic
        • 1. Re: ScriptUI and weird Object behaviour
          கற்பனை (Imagine) Level 3
          Hi Loic,
          I've tried ur codes,  getting the proper results that on Win7/InDesign CS5.5.   Give details about OS/ID versions.
          • 2. Re: ScriptUI and weird Object behaviour
            Hi and thank you a lot for your concern,
            It seems my issue is more related to doScript after all. I am passing the result of getItem() as a param to doScript and then comes the issue.
            For example:
            var params = [app.activeDocument,{choice:"b"}];
            function test(){
              var o = arguments[0][1];
              alert(o.reflect.properties);
            app.doScript(test, undefined, params , UndoModes.ENTIRE_SCRIPT); //No choice property
            test(params); //Choice Ok
            [EDIT]
            Yes that was all about doScript and how to pass an object as parameter.
             var params = [app.activeDocument,{choice:"b"}.toSource()];
            function test(){
            o = eval( "(" +o +")" );
            app.doScript(test, undefined, params , UndoModes.ENTIRE_SCRIPT); //Choice Ok
            But for what is worth I am on Mac OS 10.7.2
            Thanks a lot,
            Loic
