4 Replies Latest reply on Nov 30, 2011 6:03 AM by kbmercer165
    Section Headings in an Index
    kbmercer165
      Hi Friends!
      Creating a recipe book and now down to the index.  Instead of having the section headings be: "A, B, C, D, etc.", I'd like them to be the recipe book categories.  These are: "APPETIZERS, BEVERAGES, VEGETABLES, MEATS, etc."  There will not be an alphabetical listing of all the recipes in the book.  Is there a way to not display the alpha letters or a way to change the section headings from the alpha letter to the categories?  Currently using Indesign CS3.
        • 1. Re: Section Headings in an Index
          Isn't that the usual point of having an index?
          Anyway, you can but you'll have to re-do the index. Set your "Appetizers" etc. as "Level 1" and insert the appetizer recipes themselves as "Level 2". Re-generate the index, and adjust the Index Level 1 and Index Level 2 styles to fit.
          • 2. Re: Section Headings in an Index
            kbmercer165 Level 1
            Usually, but not this time.
            I did just that, but the letter "A" is still showing up and under that is Level 1 "Appetizers" and Level 2 the actual recipes...  I want that "A" above appetizers to disappear as well as the "B" and so forth.  I know I can hide the unused topics but don't seem to be able to remove the single letters.
            Thank you for your help!
            • 3. Re: Section Headings in an Index
              If you want to regenerate the index a couple of times, you can 'remove' the headings by sneakily hiding them: in their Paragraph Style, set the point size to 0.1, leading to 0, and color to [None]. Hey, no more head(ache)ings!
              • 4. Re: Section Headings in an Index
                kbmercer165 Level 1
                Thank you so much for your help!
                I'm new to InDesign and really appreciate all the help I can get!
                I feel I've had a DUH moment because the answer for me was right in front of my face!  When I "generate the index" and the dialog box appears, there's a check box to show or hide the section headings.  I hide them and viola!  No A,B,C's!  I was worried that if I hide section headings, I'd be hiding my index level headings, so I wouldn't choose it, but once I did, it put the world spinning in the right way again.!  lol
                Thanks again!
