5 Replies Latest reply on Jul 23, 2013 1:00 PM by Susan Bois
    When the user submit the form...
    darkanlovelee
      Once the user has completed the form and clicks the "Submit" button. Is there a way I can receive this information in the format of a "form" instead of the "View Responses" and "Summary Report" format? I would like to get the unlimited plus subscription but if I am unable to view all the info as a form it will not serve my purpose.
      Thanks anyone, everyone
      darkanlovelee
        • 1. Re: When the user submit the form...
          RandySwineford Adobe Employee
          Check out this FAQ I wrote up:
          http://forums.adobe.com/docs/DOC-1383
          There is no way to automatically send a PDF, you have to manually download it.
          Also, the PDF is in a "detail view" layout not the original form layout.
          Randy
          • 2. Re: When the user submit the form...
            darkanlovelee Level 1
            Thanks so much Randy. It's unfortunate that even though Adobe has such fantastic products that no one thought to allow a customer the ability to view/print/save a form in it's orginal format. I see this is a feature which is coming in the future. Thanks again
            • 3. Re: When the user submit the form...
              Susan Bois
              I am in the same boat.  It seems crazy to me that I can't get a copy of the form as they have filled it out.  If I go with the Adobe XI product I assume you get the form as it is filled out, it just does not have a submit button?
              • 4. Re: When the user submit the form...
                Genevieve Laroche Adobe Employee
                The submission works the same if you use FormsCentral for Acrobat desktop application (which comes with Acrobat Pro XI) or if you use the web version of FormsCentral. FormsCentral doesn't current auto generete the PDF Response file. You need to manually do so in the View Responses Tab after you receive the data.
                With Acrobat XI you can generate a PDF Form which doesn't have a FormsCentral submit button. You can add you own button from Acrobat which can send the filled out PDF via email directly to you. FormsCentral wouldn't be managing the data in that scenario.
                Gen
                • 5. Re: When the user submit the form...
                  Susan Bois Level 1
                  Thank you.  I think I would be better off buying Acrobat XI for my
                  needs.
                  Susan
                  Susan Bois
                  Operations Manager
                  Quality Medical Evaluations
                  sbois@QMEval.com
                  Phone:  508-898-9009
                  Cell    :  508-887-5037
                  All referrals to:
                  www.QMEval.com
                  Confidentiality notice:
                  The information accompanying this electronic transmission may contain
                  confidential or privileged information from QME, Inc. The information is
                  intended for the use of the individual named .  If you are not the
                  intended recipient, be aware that any disclosure, copying, distribution,
                  or use of the contents of this information is prohibited.  If you have
                  received this transmission in error please notify us immediately so that
                  we can arrange for retrieval of the documents at no cost to you.
