1 Reply Latest reply on Nov 29, 2011 9:19 PM by John Hawkinson
    applescript error in tutorial
    JFG5
      I'm using the Adobe InDesign CS3 Scripting Tutorial and run into trouble on page 34. I am an absolute beginner with scripting. i'm understanding everything up to this point, I've looked at the dictionary pages and just don't understand the error. My applescript editor is 2.4, which is newer than the one referenced in the tutorial, which could be a problem, I just don't know.
      so far ...
      tell application "Adobe InDesign CS3"
        --Create a new document.
                set myDocument to make document
        --Set the measurement units and ruler origin.
                set horizontal measurement units of view preferences to points
                set vertical measurement units of view preferences to points
                set ruler origin of view preferences to page origin
        --Get a reference to the first master spread.
                set myMasterSpread to master spread 1 of myDocument
        --Get a reference to the margin preferences of
        --the first page in the master spread.
                set myMarginPreferences to margin preferences of page 1 of myMasterSpread
        --Now set up the page margins and columns.
                set left of myMarginPreferences to 84
                set top of myMarginPreferences to 70
                set right of myMarginPreferences to 70
                set bottom of myMarginPreferences to 78
                set column count of myMarginPreferences to 3
                set column gutter of myMarginPreferences to 14
        --Page margins and columns for the right-hand page.
                set myMarginPreferences to margin preferences of page 2 of myMasterSpread
                set myGridPreferences to grid preferences
                set baseline division of myGridPreferences to 14
                set baseline start of myGridPreferences to 70
                set baseline grid shown of myGridPreferences to true
                set myLeftPage to page 1 of myMasterSpread
                set myRightPage to page 2 of myMasterSpread --- compiles fine to here.
      end tell
      tell myLeftPage
      set myLeftTextFrame to make text frame
      set geometric bounds of myLeftTextFrame to {70, 70, 714, 528}
      -- right here, I get "Syntax Error  A property can't go after this identifier" trying to compile, withthe "geometric bounds" highlighted,  and I don't understand what that means. It looks like the set myLeftTextFrame variable doesnt refer to the result of but to a process, "make text frame"
      set first baseline offset of text frame preferences of myLeftTextFrame to leading offset
      set text column count of text frame preferences of myLeftTextFrame to 3
      set text column gutter of text frame preferences of myLeftTextFrame to 14
      --Add a label to make the frame easier to find later on.
      set label of myLeftTextFrame to "BodyTextFrame"
      end tell
      tell myRightPage
      set myRightTextFrame to make text frame
      set geometric bounds of myRightTextFrame to {70, 84, 714, 542}
      set first baseline offset of text frame preferences of myRightTextFrame to leading offset
      set text column count of text frame preferences of myRightTextFrame to 3
      set text column gutter of text frame preferences of myRightTextFrame to 14
      set label of myRightTextFrame to "BodyTextFrame"
      end tell
      any help would be appreciated. If I need to be looking at something simpler, let me know.
