3 Replies Latest reply on Dec 1, 2011 3:19 AM by Rohit . Kumar
    lcds 3.1 hibernateannotations problem
    ecchuckles Level 1
      I'm trying to use hibernateannotations with lcds 3.1 and flexbuilder 4.5.1 and I'm having problem getting the fill operation to work, I'm not sure what I'm doing wrong
      I'm getting this error back from lcds:
      [LCDS]Exception executing assembler operation.  incomingMessage: Flex Message (flex.data.messages.DataMessageExt)
          operation = fill
          id = null
          clientId = C1DFF41D-2A96-1A63-E293-F4CB0FEEE405
          correlationId =
          destination = WrUesdDataManagerService
          messageId = 9861843C-94CA-9656-D044-F4CB1029A6AC
          timestamp = 1322661908887
          timeToLive = 0
          body =
            [[], getAllSorted, [Ljava.lang.Object;@7d6b4be5]
          hdr(DSId) = D8A3C599-C32F-EA78-D64B-978BE213BFC3
          hdr(DSEndpoint) = my-rtmp
          exception: java.lang.ClassCastException: flex.messaging.io.ArrayCollection cannot be cast to java.lang.String
          at flex.data.assemblers.HibernateAssembler.fill(HibernateAssembler.java:1034)
          at flex.data.assemblers.HibernateAssembler.fill(HibernateAssembler.java:957)
          at flex.data.adapters.JavaAdapter.invokeFillOperation(JavaAdapter.java:996)
          at flex.data.adapters.JavaAdapter.invoke(JavaAdapter.java:622)
      my actionscript looks like this:
      var param:ArrayCollection = new ArrayCollection();
                      param.addItem(jobs);
                      param.addItem("getAllSorted");
                      param.addItem([]);
                      getAllResult.token = WrUesdDataService.fill(param);
      and I've went through commenting out the various params like jobs and [] but I still get the same error
      the using lcds 3.1 doc says fills should like this
      myService.fill(myCollection, "flex:hql", "from Person p where p.firstName = ? ", ["Paul"]);
      but the compiler doesn't that syntax.
      I created the service by importing it into the data model and generating the code.
      here is my data-managementconfig.xml
      <?xml version="1.0" encoding="UTF-8"?>
      <service id="data-service"
          class="flex.data.DataService">
          <adapters>
              <adapter-definition id="actionscript" class="flex.data.adapters.ASObjectAdapter" default="true"/>
              <adapter-definition id="java-dao" class="flex.data.adapters.JavaAdapter"/>
          </adapters>
              <default-channels>
              <channel ref="my-rtmp"/>
          </default-channels>
      <destination id="WrUesdDataManagerService">
             <adapter ref="java-dao" />
             <properties>
      <source>flex.data.assemblers.HibernateAnnotationsAssembler</source>
             <item-class>gov.llnl.castlewr.model.WrUesdData</item-class>
             <scope>application</scope>
             <metadata>
            <identity property="uesdId"/>
            </metadata>
            <server>
              <fill-configuration>
                      <use-query-cache>false</use-query-cache>
                      <allow-hql-queries>true</allow-hql-queries>
                  </fill-configuration>
            </server>
            </properties>
            </destination>
      </service>
      any suggestions?
