0 Replies Latest reply on Dec 1, 2011 1:05 AM by Niall O'Donovan
    PDF Component
    Niall O'Donovan Level 7
      I have a component that is intended appear in one state and display various PDFs. I have it working when it is called the first time, however when it is called subsequently it does not load the PDF.
      I have been using the Tour de Flex approach of using a mx:HTML to show the PDF, but changed to adding elements to a spark container:
      private var pdfHTMLLoader:HTMLLoader = new HTMLLoader();
      private var pdfUIC:UIComponent;
                                    private function loadPDF():void {
        // Check to see if Adobe Reader 8.1 or higher is installed
        // Possible values:
        //         HTMLPDFCapability.STATUS_OK
        //         HHTMLPDFCapability.ERROR_INSTALLED_READER_NOT_FOUND
        //         HTMLPDFCapability.ERROR_INSTALLED_READER_TOO_OLD
        //         HTMLPDFCapability.ERROR_PREFERRED_READER_TOO_OLD
                                              if(HTMLLoader.pdfCapability == HTMLPDFCapability.STATUS_OK)
        // Use FlexGlobals variable for PDF name
                                                        var pdfRequest:URLRequest = new URLRequest(FlexGlobals.topLevelApplication.currentPDF);
                                                        pdfHTMLLoader = new HTMLLoader();
                                                        pdfHTMLLoader.width = pdfWin.width;
                                                        pdfHTMLLoader.height = pdfWin.height;
                                                        pdfHTMLLoader.load(pdfRequest);
                                                        pdfUIC = new UIComponent();
                                                        pdfUIC.addChild(pdfHTMLLoader);
                                                        pdfUIC.name = "PDFView";
                                                        pdfWin.addElement(pdfUIC); // Add the element to the pdfWin spark container
                                              } else {
                                                        Alert.show("PDF cannot be displayed. Error code:" + HTMLLoader.pdfCapability);
        // Called if window is resized
                                    private function reloadPDF():void {
                                              pdfHTMLLoader.reload();
                                    protected function backButton_clickHandler(event:MouseEvent):void
                                              pdfWin.removeAllElements();
                                              flash.system.System.gc();
                                              var eventObject:Event = new Event("hidePDF");
                                              dispatchEvent(eventObject);
      I think that the problem may be in either removing the elements or in how I am adding the HTMLLoader to the UI Component and then adding the element to the spark container.
      Niall
