• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Remove authorized devices/ UNauthorize?
New Here ,
Dec 01, 2011 Dec 01, 2011
I have a couple of devices that I want to remove from my Adobe ID but in neither case is it possible to do that on the device. If I don't remove these two devices then I will exceed my maximum limit and it will also be possible for someone else to use my Adobe ID and put material onto even more devices and lock up my ability to read the things I have paid for.
One item I need to unauthorize is a stolen Sony PRS505 reader. Obviously I can't do anything that requires me to press any buttons on that item as I do not have it. I will be replacing it and will need to authorize a new device in its place, but first need to remove the authorization belonging to the Sony - how do I do that?
The second authorization that needs to be removed is a computer whose PSU has blown. I've taken the hard drive out and mounted it onto my other PC, but I'm not able to boot it as a virtual machine or anything it's just mounted as a drive. How can I remove the authorization from that machine so I can let someone else have it? It's the only piece of private data still on that machine (it was a home theatre PC, it had next to nothing on it besides simple documents, videos, etc.) and i can't work out how to get it off as I don't have an option for uninstall or anything like that while it's mounted as a data drive.
How do I unauthorize these devices so that I can authorise two new ones in their place? (deliberate alternation of UK and US spelling so it comes up in both searches!)
Views
1.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
Dec 02, 2011 Dec 02, 2011
I have the answer to this question - it was given to me by a support rep. in the live chat support.  I don't know whether I'm at liberty to post the answer here or not.  If a moderator is viewing this, could you please advise if I would be breaking any copyright or other laws by posting the answer?
Thanks.
Votes
Translate
Translate
Report
Report
Enthusiast ,
LATEST
The authorization process works a bit differently than others.  Instead of deauthorizing getting you a device back, your activation allowance slowly increases over time (Adobe doesn't say by how much, since they reserve the right to change it based upon usage and support patterns).   The only thing that deauthorizing does is to remove your personal information (the activation info) from the device/computer.
You should continue to activate devices until you run out of allowances, and if you get an error that says your are out, when you should have more, then contacting Adobe (best throught web support) will get you activation allowance increased for you.
Votes
Translate
Translate
Report
Report
