2 Replies Latest reply on Dec 26, 2011 3:34 AM by myDwayneSmith
    Batch PDF script works in ID4 but not in ID5.5
    clearness
      this script worked flawlessly in ID4, but doesn't work in 5.5....It's a script that converts all open indd files to pdf.
      This is the error...
      AppleScript Error!
      Error Number: -2741
      Error String: Expected "," but found application constant or consideration.
      Engine: Default
      File: Users/AM/Library/Preferences/Adobe Indesign/Version 7.5/en_US/Scripts/Scripts Panel/PDFer.applescript
      Anyone know what's wrong with the script?
      This is the script:
      property convertSpotToProcess : false
      my main()
      on main()
        tell application "Adobe InDesign CS5.5"
        set alleExportFormater to name of every PDF export preset
        set alleDok to name of every document
        tell document 1
        set valgtExportFormat to (choose from list alleExportFormater with prompt "Choose PDF Setting")
        if valgtExportFormat = false then error number -128
        set targetmappe to my velgmappe()
        end tell -- doknavn
        set valgtExportFormat to PDF export preset (valgtExportFormat as text)
        repeat with ggg in alleDok
        set doknavn to ggg as text
        tell PDF export preferences
        set page range to all pages
        end tell
        set filnavn to doknavn
        if filnavn ends with ".indd" then set filnavn to text 1 thru -6 of filnavn
        set filnavn to filnavn & ".pdf"
        tell document doknavn
        if convertSpotToProcess then set convert to process of (every ink whose is process ink is false) to true
        set targetfil to (targetmappe & filnavn) as string
        with timeout of 40 * 60 seconds
        export format PDF type to targetfil using valgtExportFormat without showing options
        end timeout
        delay 1
        end tell
        end repeat
        say "Your PDFs are ready. "
        end tell
      end main
      on velgmappe()
        try
        tell me to activate
        end try
        return (choose folder with prompt "Choose Folder")
      end velgmappe
