9 Replies Latest reply on Dec 4, 2011 1:03 AM by Stephen_Spider
    Panning via changes in "Position" keyframes produces pan only at *end* of clip
    featheredtar
      Hi. I am trying to create pans across relatively short time lapse shots. When I do this by making two Position keyframes, the pan occurs quickly in the last tenth of the clip or so. To make the pan play itself out across the whole clip, I have to make Anchor Point keyframes. I wouldn't care, but you can't simply drag the image with that value-you have to manually manipulate the X & Y values.
      I don't know whether it's important, but I am working with Photo-JPEG clips that can be multiple gigabytes in size. The resolution of the images within are often above 4000x4000, which explains why I want to make pans (to show the subject at full resolution.)
      Any ideas?
      Joel
