0 Replies Latest reply on Dec 2, 2011 2:18 AM by Clookes
    Changing the color of a check mark of a checkbox when rendered as static PDF
    Clookes
      I am not sure if it's possible, but I am having trouble changing the check mark color of a checkbox in a static PDF.  It works fine if the PDF is dynamic, but it craps out when the PDF is static.
      Is there a workaround?  I don't have to change it dynamically based on user interaction, the client just wants a blue checkmark in a static PDF.  Anyone having the same issue?
                var vName = this.somExpression;
                var fieldObj = xfa.resolveNode(vName + ".ui.#checkButton");
                // set up a variable to deal with the tick colour
                var myTick = event.target.getField(this.somExpression);
                myTick.textColor = color.blue;
                fieldObj.mark = "check";
      This works when rendered as a Dynamic PDF, but myTick is always null when rendered as Static PDF
      Cheers,
      Nelson
