2 Replies Latest reply on Dec 4, 2011 4:41 AM by armandix
    loading external swf via XML
    armandix Level 1
      I like to call external swf via XML, someone can tell me how?
      how can I do to call them and load him into a attachMovie?
      please help me..
        • 1. Re: loading external swf via XML
          Chances are someone already has taken the time to tell you how, you just need to find out where - trying searching Google using search terms like "AS2 XML tutorial".  Post again if you have a specific problem you need help resolving and include the code that is giving you a problem.
          attachMovie is a library-related loading function, not an external file, so you might need to explain more about your intentions of loading an external swf and how it relates to loading a library object.
          • 2. Re: loading external swf via XML
            armandix Level 1
            So what I'm thinking of doing is through the main draw for swf another swf xml attribute.
            This loaded swf will be introduced within an attachMovie.
            Every time I load a new swf external, will within that attachMovie
