1 Reply Latest reply on Dec 4, 2011 7:36 AM by SteveRicketts
    Process terminated without establishing connection to debugger
    SteveRicketts Level 1
      I'm using FB 4.5.1 on Windows and trying to use StageVideo for a mobile app.  The video file plays, I can hear audio but no video.  In multiple posts I've seen that you need to add -swf-version=13 or -swf-version=14 to the compiler options.  I have AIR 3.1 installed on this box so I used 14 (same result with 13) and when I try to run or debug I get the launch error, Process terminated without establishing connection to debugger.
      I can use -swf-version=11 and it runs, but the video doesn't work.  I've downloaded Flash debugger 11.1 and get the same results as using 10.2.  So is my problem because FB doesn't recognize the latest version of AIR or something else?... basically, how do I fix this??
