6 Replies Latest reply on Dec 6, 2011 1:08 AM by Eugene Tyson
    Fast Display always gray
    Eugene Tyson Adobe Community Professional & MVP
      In View>Display Performance>Fast Display all the image frames become gray.
      is there any way to toggle this to a different colour?
        • 1. Re: Fast Display always gray
          I think no. See my answer here:
          http://forums.adobe.com/message/4064603#4064603
          Maybe a plug in could do that…
          Uwe
          • 2. Re: Fast Display always gray
            Cool, I thought I'd try here in case any scripters had a solution.
            It's a quandary.
            • 3. Re: Fast Display always gray
              mckayk_777 Level 2
              Command K for Preferences then in Display Performance set
              Options Fast
              Adjust View Settings Fast
              Then set Raster Images to Proxy
              • 4. Re: Fast Display always gray
                As per suggestion by Bob, here is a script to create a nonprinting layer and put rectangles on them matching the images.
                You should be able to safely delete this layer as long as you don't put anything on it yourself (that's why I set its color to Ominous Black, lock it, and restore your original layer selection).
                //DESCRIPTION:Hide Images the Blunt Way
                // Jongware, 6-Dec-2011
                // No Guarantees, Etc.
                //          Change to your favourite shade or teint or hue, please
                hideColor = app.activeDocument.swatches.item("Black");
                originalLayer = app.activeDocument.activeLayer;
                try {
                          app.activeDocument.layers.add({name:"NonPrinting", layerColor: [0,0,0], printable: false});
                } catch (_) { }
                nonvisLayer = app.activeDocument.layers.item("NonPrinting");
                nonvisLayer.locked = false;
                imageList = app.activeDocument.allGraphics;
                for (im=0; im<imageList.length; im++)
                          try { hideImage (imageList[im], hideColor); } catch (_) {}
                nonvisLayer.locked = true;
                app.activeDocument.activeLayer = originalLayer;
                function hideImage (anImage, hideColor)
                          var gb,fr,pg;
                          gb = anImage.parent.geometricBounds;
                          pg = anImage.parent;
                          while (1)
                                    if (pg instanceof Character)
                                      pg = pg.parentTextFrames[0];
                                    if (pg instanceof Document || pg instanceof Spread || pg instanceof Page)
                                              break;
                                    pg = pg.parent;
                          pg.rectangles.add(nonvisLayer, {geometricBounds: gb, fillColor:hideColor});
                ... So ... what's your beef with the Bland Gray anyway?
                • 5. Re: Fast Display always gray
                  (Wandering slightly OT)
                  I went over the UIColors array to look up if there was some indication this can be user-definable. Apparently it can't (I did succeed, however, in changing my default Preview Background to some hellish shade of purple) and none of the 'standard' colorizable items have the same shade of gray.
                  But I did notice this weird duo in the list: characterStyle.previewColor and paragraphStyle.previewColor. I can set them to a color with a script, and the Undo helpfully can "Undo Add UI Color" ... but I don't see any changes on the screen Some not-really fully implemented feature? On CS4, anyway?
                  • 6. Re: Fast Display always gray
                    Cool. Thanks Jongware.
                    I'll give it a go.
