13 Replies Latest reply on Dec 7, 2011 9:44 AM by -==cfSearching==-
    find Index for max value of array
    rking1966
      I can use arrayMax to get the max value for a small array, but I need to get which index the max value is located. That will determine which page the user goes to next. Here is my code:
      array:
      <cfset arrAverages[1]="#qryFairness.fairness#"/>
      <cfset arrAverages[2]="#qryHonesty.honesty#"/>
      <cfset arrAverages[3]="#qryCompassion.compassion#"/>
      <cfset arrAverages[4]="#qrySelfControl.SelfControl#"/>
      <cfset arrAverages[5]="#qryMoralConcern.MoralConcern#"/>
      These values are gathered from querying values stored in a table.
      I can get the max value in the array easily by:
      <cfdump var="#arrayMax(arrAverages)#">
      What I can't figure out is how to get the row in this array where that max value is located. It seems like it would be so simple, but nothing I have tried has worked.
      Richard
        • 1. Re: find Index for max value of array
          -==cfSearching==- Level 4
          For CF9 and above you can use ArrayFind/FindNoCase. Otherwise just loop through the array, and cfbreak when you find the matching value.
          • 2. Re: find Index for max value of array
            Dan Bracuk Level 5
            Or convert it to a list and use ListFind.  But what if there are two matching records?
            • 3. Re: find Index for max value of array
              rking1966 Level 1
              Dan, you have brought up a very interesting point. If arrayMax would give one of the max values if a tie occurs, that would be fine for this project as well. But I'll have to test that out. I did play with the list thing, but I couldn't get it to work that way either. I'm also going to see now if I can do this in the db and just use the max value I get there on my page.
              • 4. Re: find Index for max value of array
                If arrayMax would
                ArrayMax always returns a single value. The position of the maximum value within an array is a different story.
                What is your real goal here?
                • 5. Re: find Index for max value of array
                  rking1966 Level 1
                  So here's the whole story/goal:
                  I have a survey (one of several for this project) in which the questions are grouped and scored (just on backend - users never know). The highest average group determines which page the user is sent to next. So I'm submitting the data to the db, querying the averages for each trait, now I need to get the max average to determine which page they go to next. There are 5 groups/averages. I can put these in an array or a struct but haven't yet been able to easily pull the highest GROUP out (which would be the POSITION in the array). I can pull the highest average out, but I need the position (or group) where that max occurs. It seems like it would be such an easy thing, but I'm stuck. I know I risk overlapping entries (or querying the wrong entry) by doing this after the data is submitted into the db, but I think that risk is very small and I don't know how to better do these calculations until data is in a table.
                  As you can see, I'm not an expert user. I'm running CF8....sounds like I could use "arrayFind" if using CF9 and all would work, but that's not an option at this time.
                  • 6. Re: find Index for max value of array
                    Dan Bracuk Level 5
                    These functions will help you find the first position of the highest value in the array.
                    ArrayMax()
                    ArraytoList()
                    ListFind().
                    You can use them in separate commands or nest them in one command.
                    Google will lead you to sample code.  The search string is "Coldfusion function name".
                    • 7. Re: find Index for max value of array
                      So the "group" identifier is the array index?
                      I'm running CF8
                      Then you cannot use arrayFind.  Since you already have the maximum value you can use a from/to loop to examine each element in the array by position number.
                      <cfset maxValue = arrayMax(yourArray)>
                      <cfset positionOfMaxValue = -1>
                      <!--- found the maximum value --->
                      <cfloop from="1" to="#arrayLen(yourArray)#" index="position">
                               ... ( examine current value )...
                      </cfloop>
                      Within the loop, compare the current value to the maximum value. If they are equal, just return that position number and exit the loop.
                             <cfif yourArray[position] eq maxValue>
                                      <cfset positionOfMaxValue = position>
                                       <cfbreak>
                             </cfif>
                      As mentioned, this approach uses the first match it finds. If that is not desirable, you will need to adapt the code to suit your needs.
                      • 8. Re: find Index for max value of array
                        BKBK Adobe Community Professional & MVP
                        array:
                        You can find it in one line of code! Here is an example:
                        <cfset testArr[1]=-183>
                        <cfset testArr[2]=79>
                        <cfset testArr[3]=6>
                        Max.:  <cfoutput>#arraymax(testArr)#</cfoutput><br>
                        Index of max.: <cfoutput>#arrayfindNocase(testArr, arraymax(testArr))#</cfoutput>
                        • 9. Re: find Index for max value of array
                          arrayfindNocase
                          Unfortunately they are using CF8.
                          • 10. Re: find Index for max value of array
                            Adam Cameron. Level 5
                            You can leverage the fact that a CF array is a Java Vector, so you oculd use indexOf().
                            http://docs.oracle.com/javase/6/docs/api/java/util/Vector.html
                            This is not strictly supported, but realistically, CF is not going to reimplement arrays as anything else in the foreseeable future.
                            Adam
                            • 11. Re: find Index for max value of array
                              If you do use the underlying java object, be sure to read the api. There are subtle differences that people often overlook ... Unlike most CF array functions, indexOf() is both case and data type sensitive - and of course indexes are zero based.
                              Probably not, but generally it is still safer to code to the interface ie java.util.List rather than the implementation unless there is compelling reason to do otherwise.
                              Message was edited by: -==cfSearching==-
                              • 12. Re: find Index for max value of array
                                -==cfSearching==- wrote:
                                arrayfindNocase
                                I've just seen the fine print. Oh, well, here's yet another one-liner
                                Index of max.: <cfoutput>#listfindNocase(arrayToList(arrAverages), arraymax(arrAverages))#</cfoutput>
                                • 13. Re: find Index for max value of array
                                  Yep, if the values are numeric, there are several different ways to slice it. Since he seemed a little unfamiliar with arrays, I suggested the long hand approach to dispel some of the mystery
                                  -Leigh
