8 Replies Latest reply on Dec 6, 2011 8:46 AM by whcraft
    PLACING EXCEL FILES
    whcraft
      I am using ID CS5.  I have been placing excel tables for sometime now with minimal issues.  Now I am getting some kind of missing font warning.  I highlight the entire worksheet and change the font to what I normally use save it and then try to place it.  When I try to place it, it tells me the file that I am trying to place uses a font that is not available on my system.  I believe this is a complete load.  For the life of me I cannot figure how it thinks I'm using this font when I have clearly specified a font that is on my system.  There may be some other problem as well.  I did a test where I changed the font in the excel file to something that shows up in my ID fonts.  When I tried to place it, I got a msg telling me the font I changed it to was missing in addition to missing the font it originally told me I was missing.  I've really no idea why this is happening.  Anyone else had problems placing excel files.  I do not use the 'table' function in ID because excel has always been easier for me to use.  hope this makes sense.....
        • 1. Re: PLACING EXCEL FILES
          You might want to try clicking the square in the upper left corner of the spreadsheet to select the whole thing, then check the font.
          • 2. Re: PLACING EXCEL FILES
            whcraft Level 1
            The first thing I usually do when starting a spreadsheet is to click that
            square to select the entire worksheet.  Even after doing that I still get a
            font missing error.
            That is what makes it so frustrating, everything excel tells me shows that
            the entire sheet is the same font but I still get the error msg.  I believe
            it may have
            an issue with the particular file I am placing it in.  I tried placing it
            in a new file and did not get the warning and the bounding box did not
            contain any extra space.
            I had this problem with another file I was trying to place in this same
            publication.  I ended up printing that as a PDF and then placing it.  I
            would rather figure out
            what the problem is than go through the PDF and place method.
            • 3. Re: PLACING EXCEL FILES
              Grant H Level 4
              is Exel maybe substituting a glyph not in the font you choosing, or not changing the glyph because of same reason. What happens if you use Arial.
              G
              • 4. Re: PLACING EXCEL FILES
                whcraft Level 1
                It doesn't appear that is happening.  The only not text characters are inch
                marks and plus and equal signs.  I can highlight them in excel and it is
                the right font and can
                highlight them in ID and it shows they are the correct font.  I guess I
                will have to live with it and just use the find font feature to get rid of
                the problem once I place the file.
                • 5. Re: PLACING EXCEL FILES
                  Grant H Level 4
                  what happens if you create a table stlye with "fontFix" paragraph syle applied and apply that to the table?
                  G
                  • 6. Re: PLACING EXCEL FILES
                    whcraft Level 1
                    I'm not familiar with that procedure.  This seems to be an issue specific
                    to this file.  I would still like to know what's causing it.  I've still a
                    lot to learn.
                    For now I'll just live with the error msgs and change the fonts once the
                    file is placed.
                    • 7. Re: PLACING EXCEL FILES
                      Please turn off the autoquote on your email responses...
                      Is the default font (or the one specified in [Basic Paragraph]) in this file actually the missing font? It might not actually be the Excel file.
                      • 8. Re: PLACING EXCEL FILES
                        whcraft Level 1
                        my apologies if that did not fix the autoquote problem (lotus notes is a
                        pain).
                        I did check the basic paragraph panel but it was not the font that was
                        missing.  I did change that to the font I normally use.
                        With no document open and the character panel open it shows the font I
                        normally use so I would think that that is my default
                        font.
