1 Reply Latest reply on Dec 6, 2011 9:41 AM by Jim_Simon
    Stacking video clips in Bridge
    Stephen_Spider Level 3
      So I'm not sure what I'm doing exactly with this. I had three spanned .mxf clips as a source. I kept the flash media's file structure intact when I copied the clips to my hard drive.
      While browsing for the clips in Bridge I discovered the Stack clips command and tried it with all three clips selected. It grouped the .mxf Icons.
      Then after importing the clips I really could not see a difference in the project window.
      Normally when I import spanned clips I'll select and drag them all to the New Item button to create a sequence that serves to join the spanned clips. Then I'll drop that sequence into the master timeline.
      This time when I dropped all three clips on to the new item button, the result was three iterations of the entire spanned recording.
      So what I want some clarity on was whether the stacking command made premiere interpret the clips as contiguous, or was it because I kept the camera's file structure intact, or both?
