14 Replies Latest reply on Dec 12, 2011 5:51 AM by Crist OC/PC
    New PC i7 3930
    Crist OC/PC Level 2
      656486
      Corsair Vengeance DDR3 1600MHz 32GB CL10
      Kit w/4x 8GB, CL10-10-10-27, 1.5V, Vengeance Heatspreader, Intel P67, Z68, X79
      Varenr.:656486
      Lagerstatus:7 stk. på vej ind d. 5.dec.2011. Datoen er bekræftet af producenten.
      2.139,00 DKK4.278,00 DKK
      648701
      Intel® Core i7-3930K Processor
      Socket-LGA2011, Six Core, 3.2Ghz, 12MB, Boxed, no fan included
      Varenr.:648701
      Lagerstatus:22 stk. på lager.
      4.259,00 DKK8.518,00 DKK
      656337
      ASUS P9X79 WS, Socket-2011
      ATX, X79, 8xDDR3, 4xPCIe(3.0)x16, CFX&SLI, SATA 6Gb/s, USB 3.0, FW, EFI
      Varenr.:656337
      Lagerstatus:8 stk. på vej ind d. 6.dec.2011. Datoen er bekræftet af producenten.
      2.690,00 DKK5.380,00 DKK
      635806
      Corsair H100 Hydro Series CPU Køler
      Socket 775/1155/1156/1366/2011, AM2/AM2+/AM3, 2600 RPM, 46~92 CFM, 22~39 dBA
      Varenr.:635806
      Lagerstatus:100+ stk. på lager.
      775,00 DKK1.550,00 DKK
      598117
      Cisco SB 100 Series 8-port Gigabit
      Desktop unmanaged switch, 32 Gbps capacity, QoS 802.1P priority, Ext. PW
      Varenr.:598117
      Lagerstatus:62 stk. på lager.
      389,00 DKK389,00 DKK
      604785
      Cooler Master Silent Pro Gold 1000W PSU
      ATX 12V V2.3, 80 Plus Gold, Modular, 4x 6pin+4x 6+2pin PCIe, 9x SATA
      Varenr.:604785
      Lagerstatus:32 stk. på lager.
      1.569,00 DKK1.569,00 DKK
      649659
      CM Storm Trooper Gaming Big Tower
      Blæsere: 2x 120mm Front, 1x 200mm Topp, 1x 140mm Bag, ATX, mATX, xl-ATX, USB 3.0
      Varenr.:649659
      1.049,00 DKK1.049,00 DKK
      623543
      ASUS GeForce GTX 560Ti 1GB PhysX CUDA
      PCI-Express 2.0,"DirectCU II TOP", GDDR5, 2xDVI, native-HDMI, 900MHz
      Varenr.:623543
      1.550,00 DKK3.100,00 DKK
      653050
      Seagate Barracuda® 1TB
      SATA 6Gb/s (SATA 3.0), 64MB Cache, 7200RPM, 3,5"
      Varenr.:653050
      1.199,00 DKK2.398,00 DKK
      627397
      Samsung 27" LCD Syncmaster S27A750D
      1920x1080, 2ms, 120Hz, VGA/HDMI
      Varenr.:627397
      Lagerstatus:12 stk. på lager.
      3.995,00 DKK3.995,00 DKK
      648600
      ASUS BW-12B1LT, Blu-Ray Writer
      SATA, BD-R:12x, BD-R DL: 8x, DVD±R: 8x, Cyberlink BD Suite, 3D support, Retail
      Varenr.:648600
      Lagerstatus:47 stk. på lager.
      939,00 DKK939,00
      639424
      Corsair SSD Force Series 3, 120GB
      SATA 6 Gb/s (SATA3.0), 550MB/510MB/s read/write, SandForce® SF-2281
      Vores varenr.:639424/CSSD-F120GB3-BK
      Tilgængelighed:100+ stk. på lager.
      895,-ekskl. moms
      Im getting this tomorrow. My point is make as much Taste to Premier pro In order to find the best Performance.
      GPU´S TO TO  TASTE: GTX275, GTX460, GTS 450, GTX 560, HD 6950.
      I have the above HDD  and I like to hear some Ideas for a HDD CONFIGURTION, and if any body have good ideas to be taste please feel free.:
      3X300GB W.D. Raptor.
      2X1TB W.D. CAVIAR BLACK.
      4x1TB SEAGATE BARRACUDA
      2x120GB Corsair Force Series 3.
        • 1. Re: New PC i7 3930
          Harm Millaard Level 7
          Cristobal,
          My initial thoughts are:
          C: 120GB Corsair Force Series 3 for OS & programs.
          D: 120GB Corsair Force Series 3 for pagefile and stock footage.
          E: 3X300GB W.D. Raptor in raid0 for media cache and previews.
          F: 1TB W.D. CAVIAR BLACK for export.
          G: 4x1TB SEAGATE BARRACUDA in raid3/5 for media and projects with a dedicated raid controller.
          H: 1TB W.D. CAVIAR BLACK for backups.
          Note that I suggest to increase the number of Seagate Barracuda disks to increase performance and possibly use a QNAP or Thecus NAS for backup.
          For the video card go for the 560 Ti with 2 GB VRAM or better.
          It looks good.
          • 2. Re: New PC i7 3930
            Crist OC/PC Level 2
            Greate Harm.
            Aus have the new teghnology called Ram cache where from the OS we can set part of the ran as a cache in one of the HDD. To wich HDD will you give this ram cache??
            As well they have something called SSD cache wich let you intagrate a SSD with a HDD. Jus like a Hybritd.
            Will you use those new tegnology? and how will you use them?
            Thx.v.m.
            • 3. Re: New PC i7 3930
              Cristobal,
              With your current disks, I doubt that you can benefit from the SSD cache technology, since you already have a SSD boot disk. You could use the second SSD to complement E or G, but I don't think it will make any difference, given the speed of those raid arrays.
              AFAIK Ramcache is like a RAM disk, that takes a dedicated portion of the RAM to act like it were a disk. If my understanding is correct, then I would only consider that with 64 GB memory and then allocate 16 - 32 GB to that Ramcache.
              Unfortunately there is still a lot to be discovered about the capabilities of SB-E and the various implementations of the mobo's so definite answers are almost impossible to give at this moment, but you can offer yourself as a guinea pig in that area.
              • 4. Re: New PC i7 3930
                Crist OC/PC Level 2
                " but you can offer yourself as a guinea pig in that area."
                That is what I´m doing. I allready have some Ideas and Im  open tO try whatever in the new SB-E. I will keep the result in the PPBM5 OR 6 so every one can fallow the progress and the results.
                I have in mind that RAM cache could work like a Areca RAID controller limitted to the # of sata port on the MB. maybe Im wrong as I do not fully understand how they work.
                BTW when we will see a PP CS 6?
                • 5. Re: New PC i7 3930
                  Crist OC/PC Level 2
                  Do you think I should make taste on cs5.03 and 5.5 in order to make better comparision? or just on the 5.5?
                  • 6. Re: New PC i7 3930
                    Just CS5.5 because the number of systems with CS5.0 will be decreasing and because of the limitations of the PPBM5 benchmark. We had never expected that frame buffering would have such an impact on results but the new frame buffering architecture makes a huge difference. In the new test we try to avoid those anomalies, but that will only come out after CS6 has been published and we have had time to test the new timelines.
                    • 7. Re: New PC i7 3930
                      Crist OC/PC Level 2
                      will yuo be interested in see the result whitout O.C.?
                      • 8. Re: New PC i7 3930
                        Definitely, because it will show the benefits of overclocking.
                        • 9. Re: New PC i7 3930
                          Crist OC/PC Level 2
                          OK. I got all @ home now. I will need all posivilities os hard disk in orden to make the falow tests:
                          1.- Basic
                          Original Clock speed--->64GBRAM--->GPUS:"GTX560, GTX460, GTX275, HD69502GB.-----> Cooling system Corsair H100.---->HDD Config: all possibles----> 2 different cases see above...
                          Original Clock speed--->64GBRAM--->GPUS:"GTX560, GTX460, GTX275, HD69502GB.-----> Cooling system CUSTOM. ---->HDD Config: all possibles----> 2 different cases see above...
                          2.-Regular
                          Overclock 4.6ghz--->64GBRAM--->GPUS:"GTX560, GTX460, GTX275, HD69502GB.-----> Cooling system Corsair H100.---->HDD Config: all possibles----> 2 different cases see above...
                          Overclock 4.6ghz---->64GBRAM--->GPUS:"GTX560, GTX460, GTX275, HD69502GB.-----> Cooling system CUSTOM. ---->HDD Config: all possibles----> 2 different cases see above...
                          3.-Xtremen
                          O.C Max 5ghz aprox--->64GBRAM--->GPUS:"GTX560, GTX460, GTX275, HD69502GB.-----> Cooling system Corsair H100.---->HDD Config: all possibles----> 2 different cases see above...
                          O.C Max 5.4ghz aprox ---->64GBRAM--->GPUS:"GTX560, GTX460, GTX275, HD69502GB.-----> Cooling system CUSTOM. ---->HDD Config: all possibles----> 2 different cases see above...
                          I really apreciate help whit the HDD, as you can see this will take a lot of time. Im 100% sure I will get the maximun of this plataform as I did whit the X58  and will be very cool and informative to document all this in the PPBM so people will be able to compare whit a grate bases as I did in the ppbm5.
                          Enclose some pic to show hardware to compare.:
                          • 10. Re: New PC i7 3930
                            Crist OC/PC Level 2
                            • 12. Re: New PC i7 3930
                              arcadiabc
                              From your experince, would the performance tradre off be significant if he where to just have all those drives in raid 3/5 and have everything work off the raid? I am just thinking in terms of easy projec file management.
                              A
                              • 13. Re: New PC i7 3930
                                Bill Gehrke Adobe Community Professional & MVP
                                It is my preferred way of operating
                                • 14. Re: New PC i7 3930
                                  Crist OC/PC Level 2
                                  Bill will you tell me please which is the higher w/r speed you have registered whit the areca?
                                  Thx.
