3 Replies Latest reply on Dec 6, 2011 9:32 AM by kglad
    hi! i need help editing AS2 for a sound Simulated Spectrum
    Amelia_wolf
      hi i took this code from here http://www.pixelhivedesign.com/tutorials/Simulated+Flash+Audio+Spectrum+Analyzer/
      but i need to make that the color of the bars (little squares) change in gradient form (for example from red to green vertically) i don't know if i have to use a var or a function... i don't really know how to do it, mostly in wich part i have to insert that new code
      here's de AS.:
      1. // ---------------------------------------------
      2. // Simulated Spectrum Analyzer
      3. // Author: Max Langdon - max@pixelhivedesign.com
      4. // Site: www.pixelhivedesign.com
      5. // ---------------------------------------------
      6. spacing   = 1// Spacing between bars.
      7. margin   = 3; // Shift all bars to right.
      8. tot_bars  = 21// Total Spectrum Bars.
      9. max_height  = 20// Maximum height of line in bars.
      10. // ----------------------------------
      11. // The spectrum definitions.
      12. // ----------------------------------
      13. // low  = lowest the line(s) will go.
      14. // high = highest the line(s) will go.
      15. // n  = number of lines affected.
      16. // Make sure the sum of your n's = tot_bars.
      17. // Example Rock Spectrum.
      18. rock_spectrum = [
      19.         {low:5,high:20,n:2},
      20.         {low:12,high:20,n:8},
      21.         {low:3,high:15,n:3},
      22.         {low:7,high:15,n:3},
      23.         {low:5,high:10,n:3},
      24.         {low:0,high:5,n:2}
      25.         ];
      26. // Start the spectrum analyzer.
      27. analyzer(rock_spectrum);
      28. // ----------------------------
      29. // Simulated Spectrum Analyzer
      30. // ----------------------------
      31. // spectrum : Array Spectrum Definition.
      32. // isOn  : Boolean - Turn on or off Analyzer
      33. function analyzer(spectrum){
      34.   // Index of first bar range, first {low:#, high:#, n:#}
      35.   var curRange = 0;
      36.   // Number of lines the current range will affect.
      37.   var numLines = spectrum[curRange].n;
      38.   // Generate the vertical bar lines.
      39.   for(var i = 0; i < tot_bars; i++){
      40.     // Attach a one_bar movieclip.
      41.     var bar = this.attachMovie('one_bar','bar'+i,(i+1));
      42.     // Position the movieclip based on its width,
      43.     // spacing and margin specified in our variables.
      44.     bar._x = i * (bar._width + spacing) + margin;
      45.
      46.     // Set the bar's range to the current range.
      47.     bar.r = spectrum[curRange];
      48.     // Animate the bar vertically.
      49.     bar.onEnterFrame = function(){
      50.       // Choose a random number between the range we specified.
      51.       var h = Math.round(Math.random() * (this.r.high - this.r.low) + this.r.low);
      52.       // Using the random height, we generate more bars accordingly.
      53.       for(var i = 0; i < h; i++){
      54.         // Attach another bar.
      55.         var bar = this.attachMovie('one_bar','bar'+i,(i+1));
      56.         // Put it above the last bar.
      57.         bar._y -= i * (bar._height + spacing);
      58.         // Immediatly start fading the bar.
      59.         bar.onEnterFrame = function(){
      60.           this._alpha -= 20;
      61.           // If completely faded, remove the MovieClip.
      62.           if(this._alpha == 0) this.removeMovieClip();
      63.         }
      64.       }
      65.     }
      66.     // Countdown the number of lines we setup.
      67.     numLines--;
      68.     // If we reach 0, it is time to get the next range from our spectrum array.
      69.     if(numLines == 0) curRange++, numLines = spectrum[curRange].n;;
      70.   }
      71. }
      72. // --------------------------
      73. // Turning off the Analyzer.
      74. // --------------------------
      75. function turnOff(){
      76.   // Loop through the number of vertical lines.
      77.   for(var i = 0; i < tot_bars; i++){
      78.     var bar = this['bar'+i];
      79.     // Stop the animation.
      80.     delete bar.onEnterFrame;
      81.     // Loop through the number of bars on the line, except first one.
      82.     for(var j = 1; j < max_height; j--){
      83.       // Remove the bars.
      84.       var b = bar['bar'+j].removeMovieClip();
      85.     }
      86.   }
      87.
      88. }
      thanks you in advance
